I have same problem with this: .
Can't flash program on Quark c1000.
My question is:
power_soc_sleep() function run and not wake up function on board.So it can't detect pin.
I flash way:
How to flash program but not run code?
Hi ,
Can you please elaborate a bit more on the problem you are having ...
Grounding GPIO 15 on the board (this is on Header J15 Pin 28) will allow you to flash but will prevent the code from running. The Bootloader will stop and wait for that pin to be un-grounded before running the application code.
regards,
Michelle.
