Community
cancel
Showing results for
Search instead for
Did you mean:
RTsou
Quark C1000 QMSI v1.4.0 SPI interface problem
Hi ALL:
I used Quark C1000 (QMSI 1.1) to read/write a LoRa module with SPI interface. (ISSM version: ISSM_2016.1.067)
In QMSI 1.1, my program workable. I can read/write data via SPI-1 interface to control LoRa module.
Recently, I got new ISSM (ISSM version: ISSM_2016.2.090), it support QMSI v1.4.0.
So, I'm Update ROM with my CRB and testing with this version.
But, I have a problem at SPI interface to read/write data.
If I configure GPIO2 (AP_GPIO2_ADC2_SPI_S_SCLK) as output pin. Then SPI interface can't read/write data.
Example:
qm_gpio_port_config_t cfg;
/* Request IRQ and write GPIO port config. */
//cfg.direction = BIT(2)|BIT(4)|BIT(5)|BIT(6)|BIT(7); <=== if use this line , SPI-1 interface can't read/write data.
cfg.direction = BIT(4)|BIT(5)|BIT(6)|BIT(7); <=== if NO GPIO 2, SPI -1 interface can use.
cfg.int_en = BIT(QM_PIN_ID_3); /* Interrupt enabled. */
qm_gpio_set_config(QM_GPIO_0, &cfg);
Why the GPIO2 can't assign to output?
Please help check this problem. Thanks~
Below is my SPI and GPIO setting.
// SPI setting //
qm_pmux_select(QM_PIN_ID_42, QM_PMUX_FN_1); /* SPI1_M SCK */
qm_pmux_select(QM_PIN_ID_43, QM_PMUX_FN_1); /* SPI1_M MISO */
qm_pmux_select(QM_PIN_ID_44, QM_PMUX_FN_1); /* SPI1_M MOSI */
qm_pmux_select(QM_PIN_ID_45, QM_PMUX_FN_1); /* SPI1_M SS0 */
qm_pmux_select(QM_PIN_ID_46, QM_PMUX_FN_1); /* SPI1_M SS1 */
qm_pmux_select(QM_PIN_ID_47, QM_PMUX_FN_1); /* SPI1_M SS2 */
qm_pmux_select(QM_PIN_ID_48, QM_PMUX_FN_1); /* SPI1_M SS3 */
qm_pmux_input_en(QM_PIN_ID_43, true);
/* Initialise SPI configuration */
cfg.frame_size = QM_SPI_FRAME_SIZE_16_BIT;
cfg.transfer_mode = QM_SPI_TMOD_TX_RX;
cfg.bus_mode = QM_SPI_BMODE;
cfg.clk_divider = SPI_CLOCK_DIV;
int ret __attribute__((unused));
ret = qm_spi_set_config(QM_SPI_MST_1, &cfg);
QM_ASSERT(0 == ret);
ret = qm_spi_slave_select(QM_SPI_MST_1, QM_SPI_SS_0);
// GPIO setting //
cfg.int_type = BIT(QM_PIN_ID_3); /* Edge sensitive interrupt. */
cfg.int_polarity = ~BIT(QM_PIN_ID_3); /* Falling edge. */
cfg.int_debounce = BIT(QM_PIN_ID_3); /* Debounce enabled. */
cfg.int_bothedge = 0x0; /* Both edge disabled. */
cfg.callback = NULL;
cfg.callback_data = NULL;
QM_IR_UNMASK_INT(QM_IRQ_GPIO_0_INT);
QM_IRQ_REQUEST(QM_IRQ_GPIO_0_INT, qm_gpio_0_isr);
/* enable pullup on interrupt pin. */
qm_pmux_pullup_en(QM_PIN_ID_3, true);
Michelle_C_Intel
I have tried to reproduce your issue here - but I can't.
Can you try explicitly muxing out QM_PIN_ID_2 just to be sure it's set to the correct function ....
qm_pmux_select(QM_PIN_ID_2, QM_PMUX_FN_0);
- Michelle
RTsou
Hi Michelle :
The GPIO2 pin connected to my LoRa module RESET pin, and RESET pin is pull high.
So, I try to add below setting befor configuration GPIO.
qm_gpio_set_pin(QM_GPIO_0, QM_PIN_ID_2);
qm_pmux_pullup_en(QM_PIN_ID_2, true);
Then testing again, SPI-1 interface read/write workable.
Thanks~
