Intel® Makers
9873 Discussions
Quark C1000 flash access can't run
RTsou
Hi :
I want to write/read some data to flash system.
So, I testing Quark C1000 sample code : Flash_Access.
But, this sample seems has problem.
After running it, It always re-start program. It can't do any flash functions.
Please help check this sample. Thinks.
Debug message :
Starting: Flash
Starting: Flash
Starting: Flash
Starting: Flash
CK_Intel
Thank you for reaching out to Intel® Quark™ Microcontrollers Forum.
We will be looking into this issue and get back to you shortly.
Intel Customer Support
CK_Intel
Could you please attach the sample file for us to investigate further?
Thank you
RTsou
Hi :
We just use the sample from ISSM : Flash Access. (This app demonstrates the use of the flash controller.).
And use CRB to test it.
We didn't change any code, attach file is the main.c of this sample.
We traced this sample run, it always crush in any access flash action.
Thanks~
Community Manager
Hi Ray,
Thanks for the details.
We are checking further on this and revert in case we need some additional information.
Community Manager
Hi Ray,
It would help to know the version of ISSM you used. Please confirm if you are using ISSM_2016.2.094.
Thank you.
RTsou
Hi :
Yes, I tried with ISSM_2016.2.094.
I also tried with old version ISSM_2016.2.090.
Both have the same problem.
Thanks~
Community Manager
Hi Ray,
Thank you for the input.
I will feedback this to the developer and get back to you with the update as soon as possible.
Meanwhile, it would help to attach the full screenshot of the problem back in your reply for our better reference.
Thank you.
Community Manager
Hi Ray,
Have you seen the similar issue on other C1000 board?
RTsou
Hi :
Yes, I had try 2 CRB board. Both have the same issue.
Community Manager
Hi Ray,
Thank you for the update.
I will feedback this to the developer and get back to you as soon as possible.
Please stay tuned.
Community Manager
Hi Ray,
According to engineering, it's suggested to perform a firmware flash via CMD and firmware erase on your C1000.
You may also refer to Flash and Erase Application for Intel® Quark™ Microcontroller D2000 & C1000 BKM document for more information.
Please let me know if you any concerns in regards to this.
Thank you.
CK T
Agent under contract to Intel
