Community
cancel
Showing results for
Search instead for
Did you mean:
Quark D2000 Timers
I've been having an issue trying to get 2 Timers on the D2000 CRB working at the same time. I can get either working independently but not both together. I've based my code on the QMSI 1.1 BSP samples. The code acts as though an interrupt is missing. Below is a code snippet which demonstrates the issue I'm having. Any suggestions would be greatly appreciated.
int main(void) {
InitializeTimer0();
qm_pwm_start(QM_PWM_0, QM_PWM_ID_0);
InitializeTimer1();
qm_pwm_start(QM_PWM_0, QM_PWM_ID_1);
return 0;
static void timerCB0() {
static int ticks = 0;
QM_PRINTF("Timer0-%d\n", ticks++);
static void timerCB1() {
QM_PRINTF("Timer1-%d\n", ticks++);
static void InitializeTimer0(void) {
qm_pwm_config_t wr_cfg;
wr_cfg.hi_count = 0x2000000;
wr_cfg.lo_count = 0x2000000;
wr_cfg.mode = QM_PWM_MODE_TIMER_COUNT;
wr_cfg.mask_interrupt = false;
wr_cfg.callback = timerCB0;
wr_cfg.callback_data = NULL;
clk_periph_enable(CLK_PERIPH_PWM_REGISTER | CLK_PERIPH_CLK);
qm_pwm_set_config(QM_PWM_0, QM_PWM_ID_0, &wr_cfg);
qm_irq_request(QM_IRQ_PWM_0, qm_pwm_isr_0);
static void InitializeTimer1(void) {
wr_cfg.callback = timerCB1;
qm_pwm_set_config(QM_PWM_0, QM_PWM_ID_1, &wr_cfg);
I believe that I've found the answer to my question in the data sheet. It looks like there's only a single Timer Interrupt so the callback has to check which timer fired, ex:
static void timerCB(void *data, uint32_t timer_int) {
static int ticks0 = 0;
static int ticks1 = 0;
if (timer_int & BIT(QM_PWM_ID_0)) {
QM_PRINTF("Timer0-%d\n", ticks0++);
if (timer_int & BIT(QM_PWM_ID_1)) {
QM_PRINTF("Timer1-%d\n", ticks1++);
Sadly this means that if you have separate, totally unrelated pieces of code each using a different Timer they need to share a common callback routine.
