Community
cancel
Showing results for
Search instead for
Did you mean:
MTift
Quark X1000 PCIe only works in root port mode?
Hello everyone,
I'm a newbie so I hope I'm not asking wrong question in a wrong place and in a wrong manner
For a project which I'm working on, there will be a "CompactPCI Serial" form factor and a lot of electronic cards which will be tightly coupled with PCIe, Ethernet and SATA communications. I'm trying to tell you this link actually:
https://www.picmg.org/openstandards/compactpci-serial/ CompactPCI® Serial | PICMG
The system have a central controller (master or root) slot and other peripheral slots (slaves or endpoints). I was thinking that the slots can communicate via PCIe Gen1 or Gen2 in order to get higher bandwidth. The central processor in the central controller card will be Rangeley or Denverton family SoC. For a peripheral card, which is mainly responsible for digital or analog input-output, I may use a Quark X1000 SoC both read-write operations and PCIe and other kind of communications (Ethernet, SATA etc.). But unfortunately, quark x1000 SoC only supports root mode in PCIe. I want to make sure that this SoC only works in root port mode. If it can be work as an endpoint device, it can be the best-fit processor for my peripheral cards.
If you can answer my question, I would be grateful. I am open every kind of suggestion about the system by the way.
Thanks in advance,
Mustafa
Tags (1)
Community Manager
Hi Mustafa,
Thank you for contacting Intel Customer Support.
You've posted your question in the Galileo community. The Quark X1000 is not in the scope of this team but, we'd gladly point you in the right direction. The link to open a service ticket and receive support from the Quark X1000 experts is the following: premiersupport.intel.com .
Anyhow, we reviewed this case and believe we can offer some advice on what to consider for your project. The following documents have useful information about the supported configurations of the PCIe root ports, design considerations and more.
Quark PDG (Section 4): https://www-ssl.intel.com/content/dam/www/public/us/en/documents/guides/quark-x1000-platform-design-...
Quark UEFI Firmware Writers Guide (Section 13): https://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-uefi-firmware-writers-gu...
Please review these documents and see some of the capabilities of the Quark x1000.
We hope this information helps you. If you need further assistance, please contact the Quark x1000 team, they'll be able to provide much detailed information on the matter. Have a nice day.
-Sergio A
