Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Quark_v1.2.1.1 board not bootup.
Hello everyone.
I follow the chapter 6 of X1000_BSP_BuildGuide_329687_010US.pdf .
Making the sdcard images and port on sdcard.
but board id not bootup .
it is stop after below message
[Linux-EFI, setup=0x10be, size=0x22dc30]
[Initrd, addr=0xd60c000, size=0x361ea5]
so please help to solve this ....
Thanks in indvance
Community Manager
In what OS did you build this image? Did the boot process hangs or was it completed? Did you updated the board's firmware? Did you see any errors while building the image?
-Sergio
Community Manager
1) I am using the 14.04.1-Ubuntu OS.
2) Please check below is my log
Found layout.conf @ 0xffcff000 len 0x00000c14
# WARNING: this file is indirectly included in a Makefile where it
# defines Make targets and pre-requisites. As a consequence you MUST
# run "make clean" BEFORE making changes to it. Failure to do so may
# result in the make process being unable to clean files it no longer
# has references to.
[main]
size=8388608
type=global
[MFH]
version=0x1
flags=0x0
address=0xfff08000
type=mfh
[Flash Image Version]
type=mfh.version
meta=version
value=0x01000200
[ROM_OVERLAY]
address=0xfffe0000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_BOOTROM_OVERRIDE.Fv
type=some_type
[signed-key-module]
address=0xfffd8000
item_file=config/SvpSignedKeyModule.bin
svn_index=0
type=some_type
in_capsule=no
# On a deployed system, the SVN area holds the last known secure
# version of each signed asset.
# TODO: generate this area by collecting the SVN from the assets
# themselves.
[svn-area]
address=0xfffd0000
item_file=config/SVNArea.bin
type=some_type
# A capsule upgrade must implement some smart logic to make sure the
# highest Security Version Number always wins (rollback protection)
in_capsule=no
[fixed_recovery_image]
address=0xfff90000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_RECOVERY_IMAGE1.Fv
sign=yes
type=mfh.host_fw_stage1_signed
svn_index=2
# in_capsule=no
[NV_Storage]
address=0xfff30000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_NVRAM.bin
type=some_type
[RMU]
address=0xfff00000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/RMU.bin
type=none_registered
[boot_stage1_image1]
address=0xffec0000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_BOOT_STAGE1_IMAGE1.Fv
sign=yes
boot_index=0
svn_index=1
[boot_stage1_image2]
address=0xffe80000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_BOOT_STAGE1_IMAGE2.Fv
sign=yes
boot_index=1
svn_index=1
[boot_stage_2_compact]
address=0xffd00000
item_file=../../Quark_EDKII/Build/QuarkPlatform/RELEASE_GCC/FV/FlashModules/EDKII_BOOT_STAGE2_COMPACT.Fv
sign=yes
type=mfh.host_fw_stage2_signed
svn_index=3
[Ramdisk]
address=0xffa60000
item_file=../../meta-clanton/yocto_build/tmp/deploy/image-spi-galileo/image-spi-galileo-clanton.cpio.lzma
sign=yes
type=mfh.ramdisk_signed
svn_index=7
[LAYOUT.CONF_DUMP]
address=0xffcff000
type=mfh.build_information
meta=layout
[Kernel]
address=0xff852000
item_file=../../meta-clanton/yocto_build/tmp/deploy/image-spi-galileo/bzImage
sign=yes
type=mfh.kernel_signed
svn_index=6
[grub.conf]
address=0xff851000
item_file=grub/grub-spi.conf
sign=yes
type=mfh.bootloader_conf_signed
svn_index=5
[grub]
address=0xff800000
item_file=../../meta-clanton/yocto_build/tmp/deploy/image-spi-galileo/grub.efi
sign=yes
fvwrap=yes
guid=B43BD3E1-64D1-4744-9394-D0E1C4DE8C87
type=mfh.bootloader_signed
svn_index=4
at here it is stop
3) No I have not update the board's firmware..
4) no there is no any error. but some warning regarding EFL..........
Please check above answer and reply as soon as fast.
Thanks in advance..
Community Manager
First, I'd recommend you to update the board's firmware. You can see instructions here https://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf https://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf .
Can you list all the steps you followed to build this image?
-Sergio
Community Manager
I follow below command to make the images.
# tar -xvf meta-clanton_v1.2.1.1.tar.gz
# cd meta-clanton_v1.2.1.1
# ./setup.sh
# source ./oe-init-build-env yocto_build
# bitbake image-full
from above command there wil creat the blow images in tmp/deploy/images/quark directory.
file Names SIZEbzImage--3.14-r0-quark-20160726103211.bin 2.3 MBboot/grub/grub.conf 946 bytescore-image-minimal-initramfs-quark-20160726103211.rootfs.cpio.gz 3.5 MBimage-full-quark-20160726124629.rootfs.ext3 314.6 MB
i rename the above file as below
bzImage
boot/grub/grub.conf
core-image-minimal-initramfs-quark.cpio.gz
image-full-quark.ext3
and put these all 4 files in sdcard.
also note that my current board version is 1.0.2
please tell me it is must require to change the firmware 1.0.2 to 1.0.4?
ans please tell me why?
thanks in advance
Padraig_C_Intel
Hi Nikunj_Patel,
I have two questions for you:
1. Do you have access to a Debian distro?
2. Are you working behind any proxy?
Community Manager
Hello;
1) I have no access to a Debian distro?
2) No I have direct use of internet.
Thanks in advance.
Community Manager
It's recommended you update your board's firmware version. You can see instructions here https://downloadcenter.intel.com/download/24748/Intel-Galileo-Firmware-Updater-and-Drivers-1-0-4 https://downloadcenter.intel.com/download/24748/Intel-Galileo-Firmware-Updater-and-Drivers-1-0-4 .
Additionally, there's a thread with a very similar issue to yours. You can see it here /thread/100732 https://communities.intel.com/thread/100732 . The user managed to build the Quark BSP 1.2.1.1. Check the suggestions and let us know your results.
-Sergio
Community Manager
Do you still need help with this thread, were you able to build the BSP?
-Sergio
Community Manager
Upon reviewing the Quark BSP I noticed that you need to do some changes to the names of the files in /tmp/deploy/images/quark/.
You renamed some of these files but I wanted to check if you still kept the proper extensions such as in bzImage.bin. The file names should look like this:
bzImage.bin
grub.efi (This file was not in the files you mention after renaming)
boot (directory)
Can you attach a picture of the contents of the SD card?
-Sergio
Community Manager
Hi Nikunj,
Do you still need assistance with this thread? What was the result of following @Padraigc's suggestion? If you still need assistance, please answer our questions from our latest reply /message/415517# 415517 https://communities.intel.com/message/415517# 415517 .
We'll be waiting for your response.
-Sergio
Community Manager
Hello;
I have update the firmware from 1.0.2 to 1.1.0.
but still problem is not solve.
when I run the bit-bake image-full command there is some warning as below.
nikunj.patel.369@slade001:~/workspace/1.2.1/build$ bitbake image-full
Loading cache: 100% |# | ETA: 00:00:00
Loaded 5 entries from dependency cache.
Parsing recipes: 100% |# | Time: 00:00:22
Parsing of 906 .bb files complete (2 cached, 904 parsed). 2209 targets, 182 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.24.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-14.04"
TARGET_SYS = "i586-poky-linux"
MACHINE = "quark"
DISTRO = "iot-devkit"
DISTRO_VERSION = "1.5"
TUNE_FEATURES = "m32 i586"
TARGET_FPU = ""
meta
meta-yocto
meta-intel-iot-devkit
meta-intel-iot-middleware
meta-intel-quark
meta-intel-galileo
meta-netcontiki
meta-networking = "master:6c4237fcb4dec474f6275c36a85012fa8e2fa10f"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: radvd: No generic license file exists for: radvd in any provider
NOTE: validating kernel config, see log.do_kernel_configcheck for details
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/udev/bin/udevadm' has relocations in .text [textrel]
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/systemd-vconsole-setup/lib/systemd/systemd-vconsole-setup' has relocations in .text [textrel]
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/systemd-analyze/usr/bin/systemd-analyze' has relocations in .text [textrel]
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/systemd-binfmt/lib/systemd/systemd-binfmt' has relocations in .text [textrel]
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/systemd-ptest/usr/lib/systemd/ptest/test-udev' has relocations in .text [textrel]
WARNING: QA Issue: ELF binary '/home/nikunj.patel.369/workspace/1.2.1/build/tmp/work/i586-poky-linux/systemd/1_216+gitAUTOINC+5d0ae62c66-r0/packages-split/systemd/bin/systemd-sysusers' has relocations in .text [textrel]
WARNING: The postinstall intercept hook 'update_icon_cache' failed (exit code: 127)! See log for details!
WARNING: The postinstall intercept hook 'update_pixbuf_cache' failed (exit code: 2)! See log for details!
NOTE: Tasks Summary: Attempted 3054 tasks of which 19 didn't need to be rerun and all succeeded.
Please help me to solve the problem.
Thanks in advance
Community Manager
According to the output you posted you don't have any errors, just warning messages. The tasks summary says all tasks succeeded. Are you able to boot the image after running bitbake?
The warning messages mention a cache fail and a suggestion to check log for details. What are the contents of this log?
-Sergio
Community Manager
Thanks for answer
I am not able to boot the image after running bitbake.
Please help to solve the problem.
Thanks in advance.
Community Manager
Pleae check out both images.
I have try with both these options.
but still board not bootup.
Thanks in advance.
Community Manager
Did you do any modifications or performed additional steps to what's in the guide? If you did, name those modifications.
Also, take a look at this note on the BSP and make sure you're avoiding cross-pollution: Remove all previous versions of the software before installing the current version. Individual components require very different environments (compiler options and others). To avoid cross-pollution, the commands in each section that follows must be run in a new command line window every time.
At the beginning of section 6, the dependencies are listed, how did you install these dependencies? Did you receive any errors?
-Sergio
Padraig_C_Intel
Hi Nikunj_Patel,
What type of filesystem are you using on the SD card? (i.e. is it FAT32?)
Padraig
Community Manager
Yes I am using the FAT32 file system on sdcard.
I also note down that the 1.1.0 version is runs fine on my board.
Thanks in advance.
Padraig_C_Intel
Hi Nikunj_Patel,
Ok, that's what you need, after messing around a bit I can get these warnings:
WARNING:The postinstall intercept hook 'update_icon_cache' failed (exit code: 127)! See log for details!
WARNING:The postinstall intercept hook 'update_pixbuf_cache' failed (exit code: 2)! See log for details!
And the image still runs, which points towards the other warning messeges you received to be what's causing your problem.
Can you please check what version of gcc you have?
Padraig
Community Manager
Hello
Thanks for your reply.
i use the SDK 1.2.1.
i had not any change in sdk. so the default sdk is run from sdk 1.2.1
Thanks in advance.
Padraig_C_Intel
Hi Nikunj_Patel,
Ok perfect, could you also try and type this into the command line:
gcc --version
Padraig
