Community
cancel
Showing results for
Search instead for
Did you mean:
MGutb
Question - XDK with Node.js update to Version 12
Jump to solution
Hello together,
I want to work with XDK Studio and update the actual Node.js Version (v.0.10.38).
Online is a Version 0.12.7 , how can I update Node.js so that I can later work on with the XDK Studio without any Problems?
Thx,
Matthias
Tags (1)
Carlos_M_Intel
Hi MatthiasDev ,
With the latest release you shouldn't have problems to use the https://software.intel.com/iot/downloads XDK
And if you want to update the NodeJS version you could do it by installing the sourcefiles from: https://nodejs.org/dist/v0.12.7/node-v0.12.7.tar.gz https://nodejs.org/dist/v0.12.7/node-v0.12.7.tar.gz
Take a look at thehttps://github.com/joyent/node GitHub of NodeJS, you will find the instructions there
./configure
make
make install
Charlie
Carlos_M_Intel
Hi MatthiasDev ,
./configure
make
make install
Charlie
