I want to build some products with the compute stick but I need to ask the following questions:
1. How is power supplied to the stick?
2. Can it work in Extreme temperatures?
3. Where are the detailed documentation on this product?
4. Will wireless ever be embedded in this device?
5. How do I connect to this to multi-monitors? I see only 1 usb port.
6. How do I manage this(Firmware and software updates)?
1. The stick gets its power from the supplied ac adapter, "OR" from a monitor/other USB port (provided the port can supply the needed power).
2. Define "extreme". Otherwise, review page 27, table 7 of this document: http://downloadmirror.intel.com/25638/eng/STK2m3W64CC_STK2mv64CC_STK2m364CC_TechProdSpec01.pdf http://downloadmirror.intel.com/25638/eng/STK2m3W64CC_STK2mv64CC_STK2m364CC_TechProdSpec01.pdf
3. https://www-ssl.intel.com/content/www/us/en/compute-stick/intel-compute-stick.html Introducing the Intel® Compute Stick, http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005985.html Technical Product Specifications for the Intel® Compute Stick
4. WiFi and Bluetooth have always been there.
5. The stick plugs in to a HDMI monitor or TV. You can use the USB port for a USB monitor dongle. You can use the USB port for a USB hub (which might support multiple USB monitor dongles).
6. You manage the stick just like you would any PC or laptop.
You may want to review these links:
http://www.intel.com/buy/us/en/catalog/desktop/computesticks Intel Shop
Doc
Doc
Hi Al,
First, thanks for your prompt replies.
Q1: Thanks
Q2: Extreme is not 32 - 95 degrees F....Quark could do extreme temperatures (-40 - 185 F/-40 - 85 C)
Q3: Thanks
Q4: Thanks
I'm sorry for some of my questions, I read about problems with the remote keyboard app and I though I should ask management questions
http://www.intel.com/content/www/us/en/support/boards-and-kits/000016217.html?wapkw=compute+stick+do... http://www.intel.com/content/www/us/en/support/boards-and-kits/000016217.html?wapkw=compute+stick+do...
Do you have nay idea on how I can make this work in Extreme temperatures?
Perhaps one of the Intel support staff can help with this.
Doc
Hello Carlisle1500,
Thank you for joining the Intel communities.
Intel has not validated this unit to work at high temperatures, we can recommend using the unit at a temperature that you already saw in the datasheet, other than we cannot guarantee full functionality at high temperatures.
Perhaps other customers who have tested this unit at high temperature can help you posting a suggestion on this thread.
Best wishes,
Ivan
