Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Questions on Edison Bluetooth behavior
My application interface to Edison Bluetooth controller via HCI . When app send the following HCI commands to Edison BT controller,
1) < HCI Command: Reset (0x03|0x0003) plen: 0 [ 01 03 0C 00 ]
2) < HCI Command: Set Event Mask (0x03|0x0001) plen: 8 [ 01 01 0C 08 FF FF FB FF 07 F8 BF 3D ]
3) < HCI Command: LE Set Event Mask (0x08|0x0001) plen: 8 [ 01 01 20 08 1F 00 00 00 00 00 00 00 ]
4) < HCI Command: LE Set Advertising Enable (0x08|0x000A) plen: 1 [ 01 0A 20 01 01 ]
I noticed via hcidump the following communication was happening between host (my app on Edison) and the Edison bluetooth controller:
(1)
< HCI Command: Reset (0x03|0x0003) plen 0
> HCI Event: Command Complete (0x0e) plen 4
Reset (0x03|0x0003) ncmd 1
status 0x00
(2)
< HCI Command: Set Event Mask (0x03|0x0001) plen 8
Mask: 0xfffffbff07f8bf3d
Set Event Mask (0x03|0x0001) ncmd 1
status 0x00
(3)
< HCI Command: LE Set Event Mask (0x08|0x0001) plen 8
mask 0x1f00000000000000 (Reserved)
LE Set Event Mask (0x08|0x0001) ncmd 1
status 0x00
(4)
< HCI Command: LE Set Advertise Enable (0x08|0x000a) plen 1
LE Set Advertise Enable (0x08|0x000a) ncmd 1
status 0x00
(5)
< HCI Command: LE Set Advertising Data (0x08|0x0008) plen 32
LE Set Advertising Data (0x08|0x0008) ncmd 1
status 0x00
My Question is, why there is a 5th command/event that is captured by hcidump when my app isn't sending it ??
It seems to me the LE Set Advertising Data is automatically sent, and the Advertising Data (in the plen 32) includes the name I assigned to my Edison. Why is this packet sent to the Edison BT controller ?
BT = Bluetooth.
Highlighted
Re: Questions on Edison Bluetooth behavior
Hi clashion,
I'm not sure I haven't used LE that much. Have you tried using another method to see the transferred raw data? Similar to the one showed in Section 6.5 of this http://www.intel.com/support/edison/sb/CS-035381.htm Guide. This might give you more information on the data.
JPMontero_Intel
Highlighted
Hi clashion
Do you still have issues or questions about bluetooth?
Have you tried the suggestion above?
Regards;
CMata
Highlighted
CMata_Intel , JPMontero_Intel,
Nope, I do not find the answer in the Edison Bluetooth Guide pdf. It's ok, I'll accept the behavior as observed and work around it. Thanks.
