Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
REST API - C intel edison submitdata error 1404
Hi guys,
I'm trying to use C- API to access at rest service of intel iot cloud.
When I try to submit data with
response_temperature = submitData("temperature", "26.15");
printf("Response Received :%s\n", response_temperature);
Server response is:
Response Received :{"code":404,"data":{"code":1404,"message":"Device not found in IoT cloud. Try initializing and activating the device once again."}}
The url generated from submitData is:
https://dashboard.us.enableiot.com/v1/api/data/02-00-86-9f-0d-3b
with body
body: {"on":1471383109000,"accountId":"f4b1e5f2XXXXXXXXXXXXXXX","data":[{"componentId":"temperature.v1.0","on":1471383109000,"value":"26.15"}]}
In accord with https://github.com/enableiot/iotkit-api/wiki/Data-API Data API · enableiot/iotkit-api Wiki · GitHub
The device results activated and the proof is that :
isActivated = isDeviceActivated();
return true both before and after submitData.
Can anyone help me?
Thanks a lot.
Community Manager
Hi Vale,
Could you please share all the steps that you're following? I would like to take a look at the process to see if I can reproduce the issue, so every detail will be of help.
I would also suggest you to check these two links:
http://www.programmableweb.com/news/how-to-add-restful-api-to-intel-edison-and-work-it/sponsored-con... http://www.programmableweb.com/news/how-to-add-restful-api-to-intel-edison-and-work-it/sponsored-con...
https://thedrunkendeveloper.wordpress.com/2015/02/15/rest-easy-an-edison-project/ https://thedrunkendeveloper.wordpress.com/2015/02/15/rest-easy-an-edison-project/
-Pablo
Community Manager
Hi ,
Thanks for your help, but I have already solved: after creating the component, I used the "add component" function, then with "submit data" function I sent data on IoT cloud and it seems to work! The code is the following:`char *response_comp=NULL;  ComponentCatalog *cmpObject = createComponentCatalogObject("temper", "1.0", "sensor", Number", "float", "Degrees Celsius", "timeSeries");  addMinValue(cmpObject, -150.0f);  addMaxValue(cmpObject, 150.0f);   response_comp = createAnComponentCatalog(cmpObject);  char *response = NULL; response = listAllComponentCatalogs();  char *response_problema = NULL;  response_problema = addComponent("temper", "temperature.v1.0");  char *response_temperature;  response_temperature = submitData("temper", "26");`
Community Manager
Hi Vale,
I'm really happy to know that you made it work . Let us know if you have any other question in the future questions and we will help you.
-Pablo
