Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
RTL8192CU Wireless Driver
Does anyone use RTL8192CU USB WIFI adapter on Galileo board?
I built an image adding RTL kernel modules. My system detects RTL8192CU. But it doesn't work.
'ifconfig' doesn't show WLAN setting.
'lsusb' returns:
Bus 002 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n W
LAN Adapter
'iwconfig' returns:
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry long limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:off
'lsmod' returns:
rtl8192cu 92520 0
rtlwifi 98674 1 rtl8192cu
rtl8192c_common 62239 1 rtl8192cu
mac80211 234024 3 rtlwifi,rtl8192c_common,rtl8192cu
cfg80211 171950 3 iwlwifi,mac80211,rtlwifi
gpio_sch 12983 2
rfkill 20724 2 cfg80211
intel_cln_gip 20101 4
uio 14412 1 intel_cln_gip
spi_pxa2xx_pci 13049 1 spi_pxa2xx
evdev 17378 0
mmc_block 26513 2
ehci_pci 12656 0
ehci_hcd 40376 1 ehci_pci
ohci_hcd 26434 0
sdhci_pci 18191 0
sdhci 27440 1 sdhci_pci
led_class 13282 1 sdhci
stmmac 48422 0
usbcore 140133 6 rtlwifi,usbserial,ohci_hcd,ehci_hcd,ehci_pci,rtl8192cu
Any comment or advice will be appreciated.
Tags (3)
Highlighted
New Contributor II
Re: RTL8192CU Wireless Driver
What do you mean with "It doesn't work?" - According to your informations, it is not connect to a network. Did you configure the Galileo to access your Wlan network?
Highlighted
Yes I actually configured wlan0 interface in /etc/network/interfaces as below because it didn't show up automatically.
Device doesn't get an IP address assigned with the setting.
Thank you.
auto wlan0
iface wlan0 inet dhcp
wpa-proto RSN
wpa-ssid CISCO-N
wpa-key-mgmt WPA-PSK
wpa-group TKIP CCMP
wpa-pairwise TKIP CCMP
wpa-psk 0d1c3a2cb2ba0ca28b5f49a4af5514c666725ce30a35fc2eb2b3a1c8a803cf7f
Highlighted
New Contributor II
My config looks like this:
auto wlan0
wireless_mode managed
wireless_essid
wpa-driver wext
wpa-conf /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
ssid=""
psk=
Does "ifup wlan0" show any messages?
Highlighted
"ifup wlan0" returns:
"SIOCSIFFLAGS: Operation not possible due to RF-kill"
"rfkill list all" returns:
0: phy0: wlan
Soft blocked: yes
Hard blocked: no
Highlighted
New Contributor II
The internet seems to be familiar with this problem:
https://www.google.de/search?q=SIOCSIFFLAGS:+Operation+not+possible+due+to+RF-kill&ie=utf-8&oe=utf-8... q=RTL8192CU+SIOCSIFFLAGS:+Operation+not+possible+due+to+RF-kill&rls=org.mozilla:de:official&safe=off&start=0 https://www.google.de/search?q=SIOCSIFFLAGS:+Operation+not+possible+due+to+RF-kill&ie=utf-8&oe=utf-8... q=RTL8192CU+SIOCSIFFLAGS:+Operation+not+possible+due+to+RF-kill&rls=org.mozilla:de:official&safe=off&start=0
Try:
rfkill unblock wifi
