Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Read/Write to Serial Port - JavaScript (help)
KSels
New Contributor II
I got an javascript reading GPS data from an Arduino GPS board.
Reading the GPS data is ok, I cant send data to the GPS unit to change the data output from the GPS unit.
what can I do?
Here is my code.
var m = require('mraa'); //require mraa
var fs = require('fs'); // require filesystem
u = new m.Uart(0); // /dev/ttyMFD1
console.log(u.getDevicePath());
var SerialPort = require("serialport").SerialPort; // npm install serialport
var serialPort = new SerialPort("/dev/ttyMFD1", {
baudrate: 9600
// Program GPS module
serialPort.on('write', writeData);
function writeData(){
serialPort.write("$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"); // RMC and GGA
// receive GPS (approx every second)
serialPort.on("open", function () {
console.log('GET GPS data');
serialPort.on('data', function(data) {
var data_string = '' + data
//console.log(data_string);
if (data_string.substring(0,6) == '$GPGGA') {
gpgga_string = data_string.split('\n')[0];
gpgga_string = gpgga_string.replace('\n', '');
gps_data = gpgga_string.split(',');
console.log('data received: ' + gps_data);
var time_string = gps_data[1];
var gps_time = new Date();
var gps_time_hours = parseInt(gps_data[1].substring(0,2));
var gps_time_minutes = parseInt(gps_data[1].substring(2,4));
var gps_time_seconds = parseInt(gps_data[1].substring(4,6));
gps_time.setHours(gps_time_hours);
gps_time.setMinutes(gps_time_minutes);
gps_time.setSeconds(gps_time_seconds);
gps_lat = gps_data[2];
gps_lat_ns = gps_data[3];
gps_lon = gps_data[4];
gps_lon_ew = gps_data[5];
gps_pos_fix = gps_data[6];
gps_satt_qty = gps_data[7];
gps_hdop = gps_data[8];
gps_msl_alt = gps_data[9];
gps_unit = gps_data[10];
gps_geo = gps_data[11];
gps_geo_unit = gps_data[12];
if (gps_pos_fix == '1') {
console.log('GPS Fixed');
console.log('Time: ', gps_time);
console.log('Position: ' + gps_lat + gps_lat_ns + ',' + gps_lon + gps_lon_ew);
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + gps_hdop + 'M');
console.log('Satellites Qty: ' + gps_satt_qty + '\n');
if (gps_pos_fix == '0') {
console.log('No GPS Fix');
// console.log('GPS Fix: ' + gps_fix_stat);
// console.log('Time: ', gps_time);
// console.log('Position: ' + gps_lat + gps_lat_ns + ',' + gps_lon + gps_lon_ew);
// console.log('Altitude: ' + gps_geo + 'M' + ' +/- ' + gps_hdop + 'M');
// console.log('Satellites Qty: ' + gps_satt_qty + '\n');
// NOTE:
// such as the awesome http://www.hhhh.org/wiml/proj/nmeaxor.html http://www.hhhh.org/wiml/proj/nmeaxor.html
//# define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
//# define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
//# define PMTK_SET_NMEA_UPDATE_10HZ "$PMTK220,100*2F"
//# define PMTK_SET_BAUD_57600 "$PMTK251,57600*2C"
//# define PMTK_SET_BAUD_9600 "$PMTK251,9600*17"
// standby command & boot successful message
//# define PMTK_STANDBY "$PMTK161,0*28"
//# define PMTK_STANDBY_SUCCESS "$PMTK001,161,3*36" // Not needed currently
// turn on only the second sentence (GPRMC)
//# define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
// turn on GPRMC and GGA
//# define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn on ALL THE DATA
//# define PMTK_SET_NMEA_OUTPUT_ALLDATA "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn off output
//# define PMTK_SET_NMEA_OUTPUT_OFF "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
//Active Interference Cancellation (AIC) - gives better navigation quality
//$PMTK286,1*23 - Enable
//$PMTK286,0*22 - Disable
KSels
New Contributor II
I am gething closer to the end, I am able to read the GGA data, but now I want to read the GGA and RMC data, got any hints??
Using an Level shifter did not work, probably wrong connections, sow I programmed the Sparkfun Arduino board.
Sparkfun Arduino Code:
# include
SoftwareSerial mySerial(10, 11); // TX - GSM, RX - GSM
void setup()
// Open serial communications and wait for port to open:
Serial.begin(9600);
mySerial.begin(9600);
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
while(Serial.available())
mySerial.write(Serial.read());
mySerial.println();
JavaScript Code on Intel Edison:
baudrate: 9600
// receive GPS (data)
var PMTK_SET_NMEA_UPDATE_1HZ = "$PMTK220,1000*1F"
var PMTK_SET_NMEA_UPDATE_5HZ = "$PMTK220,200*2C"
var PMTK_SET_NMEA_UPDATE_10HZ = "$PMTK220,100*2F"
var PMTK_SET_NMEA_OUTPUT_RMCONLY = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
// turn on RMC and GGA
var PMTK_SET_NMEA_OUTPUT_RMCGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn on RMC, GGA and GSA
var PMTK_SET_NMEA_OUTPUT_RMCGGAGSA = "$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
var PMTK_SET_NMEA_OUTPUT_ALLDATA = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn off output
var PMTK_SET_NMEA_OUTPUT_OFF = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// Standby
var PMTK_STANDBY = "$PMTK161,0*28"
var PMTK_Q_RELEASE = "$PMTK605*31"
// Ant off
var PMTK_ANT_OFF = "$PGCMD,33,0*6D"
// Active Interference Cancellation (AIC) Disable
var PMTK_AIC_OFF = "$PMTK286,0*22"
// Active Interference Cancellation (AIC) Enable
var PMTK_AIC_ON = "$PMTK286,1*23"
serialPort.write(PMTK_SET_NMEA_OUTPUT_RMCGGA + "\r\n"); // RMC and GGA
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 5Hz
serialPort.write(PMTK_AIC_ON + "\r\n"); // AIC ON
Pablo_M_Intel
Hi KimLorentz,
Could you please tell me which GPS module you are using so I can look for the datasheet? Also, is it ok that the last part of the code is commented out? Is there a reason for this?
PabloM_Intel
KSels
New Contributor II
The last part is only for notes.
Got the notes from reading the Adafruit Ultimate GPS lib.
The chips name is http://www.adafruit.com/datasheets/GlobalTop%20MT3339%20PC%20Tool%20v1.3%20without%20F2.0&I3.1.rar MT3339. Datasheet http://www.adafruit.com/datasheets/PMTK_A11.pdf http://www.adafruit.com/datasheets/PMTK_A11.pdf
It communicate true Serial data at baud rate 9600
KSels
New Contributor II
# include
void setup()
Serial.begin(9600);
mySerial.println();
baudrate: 9600
// turn off output
// Standby
// Ant off
Pablo_M_Intel
Hi KimLorentz,
To read RMC you can use the same procedure that you used for GGA. When you read the $GPRMC on the first 6 characters of the string you can split the string into a list. That list would have 13 (0-12) values. Check the format below:
[0] = Recommended Minimum Sentence C
[1] = Time in hhmmss format
[2] = Status, could be A=active or V=void
[3] = Latitude
[4] = Latitude direction
[5] = Longitude
[6] = Longitude direction
[7] = speed over the ground in knots
[8] = angle in degrees
[9] = date ddMMYY
[10] = Magnetic variation
[11] = Magnetic variation direction
[12] = Checksum data, always begin with *
You can check these two links for more information on how GGA and RMC are distributed.
GGA: http://www.gpsinformation.org/dale/nmea.htm# GGA http://www.gpsinformation.org/dale/nmea.htm# GGA
RMC: http://www.gpsinformation.org/dale/nmea.htm# RMC http://www.gpsinformation.org/dale/nmea.htm# RMC
PabloM_Intel
KSels
New Contributor II
How do I add 100-200 ms delay to the serialPort.write commands?
The write goes to fast for the GPS like it is now.
ADD DELAY HERE.
ADD DELAY HERE.
ADD DELAY HERE.
Pablo_M_Intel
Hi KimLorentz,
I believe that there's no a specific "delay" or "sleep" function in JavaScript, like there is for C, Python and some other programming languages.
However, you can use the setTimeout event.
If I'm not mistaken it goes like this:
setTimeout (function(){
//your code
}, 1000); //where 1000 is in ms
In the example above, your code will be paused by 1000ms.
PabloM_Intel
KSels
New Contributor II
I got the delay function to work.
I added this code to the js.
function delay(milliseconds)
var startTime = Date.now();
while (Date.now() - startTime < milliseconds);
At start of SerialPort.on open I added.
delay(200); // 200ms
serialPort.write(PMTK_DT_DGPS_MODE + "\r\n"); // DGPS
serialPort.write(PMTK_SET_NMEA_UPDATE_5HZ + "\r\n"); // 5Hz
The new code is:
baudrate: 9600
// Create .txt file
var ws = fs.createWriteStream('/media/sdcard/GPS.txt');
var PMTK_SET_NMEA_UPDATE_1HZ = "$PMTK220,1000*1F";
var PMTK_SET_NMEA_UPDATE_5HZ = "$PMTK220,200*2C";
var PMTK_SET_NMEA_UPDATE_10HZ = "$PMTK220,100*2F";
// Baud Rate 0(default = 9600) - 115200
var PMTK_SET_NMEA_BAUDRATE_0 = "$PMTK251,0*28";
var PMTK_SET_NMEA_BAUDRATE_4800 = "$PMTK251,4800*14";
var PMTK_SET_NMEA_BAUDRATE_9600 = "$PMTK251,9600*17";
var PMTK_SET_NMEA_BAUDRATE_14400 = "$PMTK251,14400*29";
var PMTK_SET_NMEA_BAUDRATE_19200 = "$PMTK251,19200*22";
var PMTK_SET_NMEA_BAUDRATE_38400 = "$PMTK251,38400*27";
var PMTK_SET_NMEA_BAUDRATE_57600 = "$PMTK251,57600*2C";
var PMTK_SET_NMEA_BAUDRATE_115200 = "$PMTK251,115200*1F";
var PMTK_SET_NMEA_OUTPUT_RMC = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// GGA only
var PMTK_SET_NMEA_OUTPUT_GGA = "$PMTK314,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
var PMTK_SET_NMEA_OUTPUT_RMCGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
var PMTK_SET_NMEA_OUTPUT_RMCGGAGSA = "$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
var PMTK_SET_NMEA_OUTPUT_ALLDATA = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn off output
var PMTK_SET_NMEA_OUTPUT_OFF = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// Standby
var PMTK_STANDBY = "$PMTK161,0*28";
var PMTK_Q_RELEASE = "$PMTK605*31";
// Ant off
var PMTK_ANT_OFF = "$PGCMD,33,0*6D";
var PMTK_AIC_OFF = "$PMTK286,0*22";
var PMTK_AIC_ON = "$PMTK286,1*23";
// DGPS Mode
var PMTK_DT_DGPS_MODE = "$PMTK401*37";
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGA);
delay(200);
console.log(PMTK_DT_DGPS_MODE);
delay(200);
console.log(PMTK_SET_NMEA_UPDATE_5HZ);
delay(200);
console.log(PMTK_AIC_ON);
delay(200);
var data_string = '' + data;
ws.write(data_string);
if (gps_pos_fix == '2') {
console.log('DGPS Fixed');
