Intel® Makers
9881 Discussions
Read multiple strings from serial port.
KSels
New Contributor II
I was able to read serial data from the serial port and send to console.log.
I am wondering how to save multible strings on serial port and then split the data up.
The strings are gps data.
  • String 1 = $GPGGA
  • String 2 = $GPGLL
  • String 3 = $GPGSA
  • String 4 = $GPGSV
  • String 5 = $GPGSV
  • String 6 = $GPGSV
  • String 7 = $GPGSV
  • String 8 = $GPRMC
  • String 9 = $GPVTG
Current running code.
var m = require('mraa'); //require mraa
var fs = require('fs'); // require filesystem
u = new m.Uart(0);
console.log(u.getDevicePath());
var SerialPort = require("serialport").SerialPort
var serialPort = new SerialPort(u.getDevicePath(), {
baudrate: 9600
// receive GPS (data)
var PMTK_SET_NMEA_UPDATE_1HZ = "$PMTK220,1000*1F";
var PMTK_SET_NMEA_UPDATE_5HZ = "$PMTK220,200*2C";
var PMTK_SET_NMEA_UPDATE_10HZ = "$PMTK220,100*2F";
// Baud Rate 0(default = 9600) - 115200
var PMTK_SET_NMEA_BAUDRATE_0 = "$PMTK251,0*28";
var PMTK_SET_NMEA_BAUDRATE_4800 = "$PMTK251,4800*14";
var PMTK_SET_NMEA_BAUDRATE_9600 = "$PMTK251,9600*17";
var PMTK_SET_NMEA_BAUDRATE_14400 = "$PMTK251,14400*29";
var PMTK_SET_NMEA_BAUDRATE_19200 = "$PMTK251,19200*22";
var PMTK_SET_NMEA_BAUDRATE_38400 = "$PMTK251,38400*27";
var PMTK_SET_NMEA_BAUDRATE_57600 = "$PMTK251,57600*2C";
var PMTK_SET_NMEA_BAUDRATE_115200 = "$PMTK251,115200*1F";
// turn on only the second sentence (GPRMC)
var PMTK_SET_NMEA_OUTPUT_RMC = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// GGA only
var PMTK_SET_NMEA_OUTPUT_GGA = "$PMTK314,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on RMC and GGA
var PMTK_SET_NMEA_OUTPUT_RMCGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn on RMC, GGA and GSA
var PMTK_SET_NMEA_OUTPUT_RMCGGAGSA = "$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on ALL THE DATA
var PMTK_SET_NMEA_OUTPUT_ALLDATA = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn off output
var PMTK_SET_NMEA_OUTPUT_OFF = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// Standby
var PMTK_STANDBY = "$PMTK161,0*28";
var PMTK_Q_RELEASE = "$PMTK605*31";
// Ant off
var PMTK_ANT_OFF = "$PGCMD,33,0*6D";
// Active Interference Cancellation (AIC) Disable
var PMTK_AIC_OFF = "$PMTK286,0*22";
// Active Interference Cancellation (AIC) Enable
var PMTK_AIC_ON = "$PMTK286,1*23";
// DGPS Mode
var PMTK_DT_DGPS_MODE = "$PMTK401*37";
// Starting logging data to SD
var GPS_log = false;
function delay(milliseconds)
var startTime = Date.now();
while (Date.now() - startTime < milliseconds);
serialPort.on('open',function() {
console.log('Port open');
serialPort.write(PMTK_SET_NMEA_OUTPUT_ALLDATA + "\r\n");
console.log(PMTK_SET_NMEA_OUTPUT_ALLDATA);
delay(500);
serialPort.write(PMTK_DT_DGPS_MODE + "\r\n"); // DGPS
console.log(PMTK_DT_DGPS_MODE);
delay(500);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n");
console.log(PMTK_SET_NMEA_UPDATE_1HZ);
delay(500);
serialPort.write(PMTK_AIC_ON + "\r\n"); // AIC ON
console.log(PMTK_AIC_ON);
delay(500);
//GPS_log = true;
// receive GPS (approx every second)
//write all received data into new_file
serialPort.on("open", function () {
serialPort.on('data', function(data) {
var data_string = '' + data
console.log(data_string);
if (data_string.substring(0,6) == '$GPGGA') {
gpgga_string = data_string.split('\n')[0];
gpgga_string = gpgga_string.replace('\n', '');
gps_data = gpgga_string.split(',');
console.log('data received: ' + gps_data);
var time_string = gps_data[1];
var gps_time = new Date();
var gps_time_hours = parseInt(gps_data[1].substring(0,2));
var gps_time_minutes = parseInt(gps_data[1].substring(2,4));
var gps_time_seconds = parseInt(gps_data[1].substring(4,6));
gps_time.setHours(gps_time_hours);
gps_time.setMinutes(gps_time_minutes);
gps_time.setSeconds(gps_time_seconds);
gps_lat = gps_data[2];
gps_lat_ns = gps_data[3];
gps_lon = gps_data[5];
gps_lon_ew = gps_data[6];
//console.log('gps_time', gps_time);
//console.log(gps_lat, gps_lat_ns);
if (data_string.substring(0,6) == '$GPRMC') {
console.log('RMC data found');
Community Manager
Hi Kim,
You could use the String.Split method. If I understand it correctly, you could set a list of chars that will be the parameters to separate/split the original string, so with this you could just make a list of possible chars that usually appear in your strings, then you pass this list of chars to detect in the original string and the String.Split method will do the job. You could check this example which is explained in more detail https://msdn.microsoft.com/en-us/library/ms228388.aspx https://msdn.microsoft.com/en-us/library/ms228388.aspx, it separates words using commas, colons, periods and tabs.
Pablo
KSels
New Contributor II
Tnx I will look at this.
Got it working, but not 100%
Here is my current code, only the GSV data is not complete(missing 3 of 4)
var com = require("serialport");
// Get Edison Time
var dat = new Date();
var day = dat.getDate();
var month = dat.getMonth() + 1;
var year = dat.getFullYear();
// Set Serial port
var serialPort = new com.SerialPort("/dev/ttyMFD1", {
baudrate: 9600,
parser: com.parsers.readline('\r\n')
// Create .txt file
//var ws = fs.createWriteStream('/media/sdcard/GPS.txt');
var ws = fs.createWriteStream('/media/sdcard/GPS.txt', {'flags': 'a'});
// GGA only
// turn off output
// Standby
// Ant off
// DGPS Mode
serialPort.write(PMTK_SET_NMEA_OUTPUT_ALLDATA + "\r\n"); // RMC and GGA
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGAGSA);
delay(500);
delay(500);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 5Hz
console.log(PMTK_SET_NMEA_UPDATE_5HZ);
delay(500);
delay(500);
GPS_log = true;
setInterval(function()
console.log('500ms' + '\n');
}, 500); // 50ms
var data_string = '' + data;
console.log('GGA data received: ' + data_string);
gprmc_string = gpgga_string.replace('*', ',');
gps_datagga = gpgga_string.split(',');
var time_string = gps_datagga[1]; // Fix Time HH:MM:SS
var gps_time_hours = parseInt(gps_datagga[1].substring(0,2));
var gps_time_minutes = parseInt(gps_datagga[1].substring(2,4));
var gps_time_seconds = parseInt(gps_datagga[1].substring(4,6));
gps_lat = gps_datagga[2]; // Latitude
gps_lat_ns = gps_datagga[3]; // Latitude
gps_lon = gps_datagga[4]; // Longitude
gps_lon_ew = gps_datagga[5]; // Longitude
gps_pos_fix = gps_datagga[6]; // Fix Quality 1-8
gps_satt_qty = gps_datagga[7]; // Number of satellites
gps_hdop = gps_datagga[8]; // Horizontal dilution of position
gps_msl_alt = gps_datagga[9]; // Altitude above sea level
gps_unit = gps_datagga[10]; // Meters
gps_geo = gps_datagga[11]; // Height of geoid above WGS84
gps_geo_unit = gps_datagga[12]; // Meters
gps_dgps = gps_datagga[13]; // DGPS laste update time
gps_dgps_id = gps_datagga[14]; // DGPS station ID number
gps_Checksum = gps_datagga[15]; // Checksum
if (gps_pos_fix == '1') {
ws.write(data_string + '\n');
console.log('GGA GPS Fixed');
console.log('Time: ', gps_time_hours + ':' + gps_time_minutes + ':' + gps_time_seconds);
console.log('Position: ' + gps_lat + gps_lat_ns + ',' + gps_lon + gps_lon_ew);
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + gps_hdop + ...
Community Manager
Hi Kim,
Please let us know what results you get once you try it out, you might save some code lines using String.Split. It's nice to know that you got it working already, I was looking at your code and I guess that the GSV and VTG () implementation is similar to the rest of them (GGA, GGL, etc.) so at the end it should work using your configuration or using the Split.String function.
Pablo
