Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Reading Parallax PIR sensor with Galileo Gen 2 and Python
I'm trying to wrap my brain around the Galileo Gen 2 and reading sensors. This is an example of the Galileo Gen 2 and the Parallax PIR sensor being monitored with python.
Wiring example:
The process is simple.
1. Initialize the digital pin.
2. Wait a few seconds for it to settle.
3. Then read the pin, it it goes high motion has been detected.
Code:
# !/usr/bin/env python
# File : pir.py An example script of reading a Parallax PIR sensor
# Author : Joe McManus mailto:josephmc@alumni.cmu.edu josephmc@alumni.cmu.edu
# Version : 0.1 02/24/2016
# Copyright (C) 2016 Joe McManus
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <</span>http://www.gnu.org/licenses/ http://www.gnu.org/licenses/>.
import argparse
import time
import mraa
import datetime
parser = argparse.ArgumentParser(description='Script to monitor PIR sensor on Intel Galileo')
parser.add_argument('pinNumber', help="The pin number the PIR is attached to. i.e. 2-13", type=int)
parser.add_argument('--version', action='version',version='%(prog)s 0.1')
args=parser.parse_args()
pin = mraa.Gpio(args.pinNumber)
pin.dir(mraa.DIR_IN)
print("Waiting for PIR to settle")
i=5
while i > 0:
print i
time.sleep(1)
i=i-1
print("Detecting movement")
try:
while True:
if pin.read():
print("Motion Detected " + str(datetime.datetime.now()))
time.sleep(2)
except:
quit()
Output:
root@galileo:~# ./pir.py 4
5
4
3
2
1
Detecting movement
Motion Detected 2016-02-25 00:08:46.188826
Motion Detected 2016-02-25 00:08:50.194598
Code can be downloaded here: https://github.com/joemcmanus/pir https://github.com/joemcmanus/pir
Thought this might be helpful for others.
Cheers,
-Joe
Tags (1)
