Community
cancel
Showing results for
Search instead for
Did you mean:
RKasu
Reading UART1 using mraa on Intel edison
I'm using Intel edison arduino expansion board with meta image.I want to integrate A6 GSM,GPRS module using digital pins 0 and 1. The mraa version I'm using is 0.9.5.I enabled the pins mentioned in the link . By using the code sample_uart.c(which is pinned below) ,I can see the output in cat /dev/ttyMFD1. But if I want to get the output in the same console,I tried mraa_uart_data_available and mraa_read function in the program basic_uart(1).c but there is no output in the same console where we are running the progarm.I tried changing the delay and adding the delay,but it is also invain.
I also tried adding libraries mentioned in the links
http://www.cmrr.umn.edu/~strupp/serial.html# 5_1 Serial Programming Guide for POSIX Operating Systems https://www.scivision.co/intel-edison-using-uart-ttymfd1-serial-port/
https://software.intel.com/en-us/articles/internet-of-things-using-mraa-to-abstract-platform-io-capa... _Toc7.1 https://software.intel.com/en-us/articles/internet-of-things-using-mraa-to-abstract-platform-io-capa... _Toc7.1
and the program is
# include /* Standard input/output definitions */
# include /* String function definitions */
# include /* UNIX standard function definitions */
# include /* File control definitions */
# include /* Error number definitions */
# include /* POSIX terminal control definitions */
# include
# include
int fd;
int counter;
int setupTTY(int fd, speed_t baud)
if (fd < 0)
return 0;
struct termios termio;
tcgetattr(fd, &termio);
cfmakeraw(&termio);
cfsetispeed(&termio, baud);
cfsetospeed(&termio, baud);
if (tcsetattr(fd, TCSAFLUSH, &termio) < 0)
//fprintf(stderr, "%s\n", "tcsetattr failed");
printf("address failed");
return 0;
return
int /* O - 0 = MODEM ok, -1 = MODEM bad */
init_uart(int fd) /* I - Serial port file */
char buffer[255]; /* Input buffer */
char *bufptr; /* Current char in buffer */
int nbytes; /* Number of bytes read */
int tries; /* Number of tries so far */
for (tries = 0; tries < 3; tries ++)
/* send an AT command followed by a CR */
if (write(fd, "AT\r", 3) < 3)
continue;
/* read characters into our string buffer until we get a CR or NL */
bufptr = buffer;
while ((nbytes = read(fd, bufptr, buffer + sizeof(buffer) - bufptr - 1)) > 0)
bufptr += nbytes;
if (bufptr[-1] == '\n' || bufptr[-1] == '\r')
break;
/* nul terminate the string and see if we got an OK response */
*bufptr = '\0';
if (strncmp(buffer, "OK", 2) == 0)
return (0);
return (-1);
int main()
ioctl(fd,FIONREAD,&counter);
mraa_init();
mraa_uart_context m_uart;
m_uart = mraa_uart_init(0);
const char *devPath = mraa_uart_get_dev_path(m_uart);
if (!devPath)
//fprintf(stderr, "%s\n", "Could not get device path");
printf("Could not get device path");
return 0;
if ((fd = open(devPath, O_RDWR)) == -1)
//fprintf(stderr, "%s\n", "Could not open device path");
printf("Could not open device path");
return 0;
if (!setupTTY(fd, B115200))
//fprintf(stderr, "%s\n", "Could not setup TTY port");
printf("Could not setup TTY port");
return 0;
else
printf("baud rate is set\n");
init_uart(fd);
/* when we are done, close the device and exit */
close(fd);
return(0);
but there seems to no output.I have tried changing baud rate too.I have tried changing the delay.Please do needful.
Thanks and Regards,
Radhika
Community Manager
Hello Radhika,
Thank you for interest in the Intel® Edison Breakout Board.
I understand that you successfully integrated your Edison Board with the GSM GPRS A6 Module through the sample_uart.c program.
You mentioned that you can see the output in cat /dev/ttyMFD1, but that you "want to get the output in the same console". Could you please confirm that you want to see the output in the terminal without using the cat /dev/ttyMFD1 command? If that is not what you are trying to accomplish, please provide a simple diagram/image/picture showing your desired setup. It may help me better understand what you are trying to accomplish.
Also, you should update your MRAA I/O and UPM sensor libraries and perform your tests again. Please follow this link for more information https://software.intel.com/en-us/node/623543.
I'll be waiting for your response.
Andres V.
Community Manager
Hello Radhika,
I was wondering if you had the chance to check the information provided.
Andres V.
