Intel® Makers
9867 Discussions
Recommended manufacturing guidelines for the Quark SE C1000?
Community Manager
Please provide the recommended manufacturing guidelines for the Quark SE.
The Curie datasheet says Intel has evaluated solder paste SAC305 Type 4 but the SE datasheet has no reflow parameters.
Is solder paste recommended for the SE? If yes, do you have a recommendation? If not, do you have a flux recommendation?
Are the BGA solder balls lead free?
CK_Intel
Thank you for reaching out to Intel® Quark™ Microcontrollers Forum.
We will look into this issue and get back to you shortly.
CK
Intel Customer Support
CK_Intel
This to inform you that there is no releasable manufacturing guideline for the product at the moment.
However, I will check with the engineering team on this issue and keep you posted when I hear any updates to pass along.
Thank you.
CK
CK_Intel
I was just told by engineering that we don't have a releasable manufacturing guideline for Intel® Quark™ SE Microcontroller C1000 at the moment.
However, you may refer to the information below on the reflow profile for manufacturing procedure in case you require.
Thank you.
CK
