Intel® Makers
9881 Discussions
Reg:Flashing of sato and Yocto images
RKasu
Hi Everyone,
I'm using the source code iot-devkit-yp-poky-edison-20160606 inorder to compile and following the steps
unzip iot-devkit-yp-poky-edison-20160606.zip
cd iot-devkit-yp-poky-edison-20160606/poky/
source oe-init-build-env ../build_edison/
bitbake edison-image u-boot
../poky/meta-intel-edison/utils/flash/postBuild.sh .
zip -r toFlash.zip toFlash
I'm facing the issue while flashing the image,I found the flash file in /core_image_sato/iot-devkit-yp-poky-edison-20160606/poky/meta-intel-edison/utils/Flash/FlashEdison.json and flashed the image using flash-to-lite then its not flashing ,I'm getting the error of Failed to start Dldr state machine aborting....
I'm not knowing why I'm facing the issue...I'm facing the same issue for both bitbake edison image and bitbake core-image-sato..But I can flash the image by using Make edison-image.
Any and Every help is appreciated.
Thanks and Regards,
Radhika
AlHill
One thread only, please. Stay with your other thread:
Doc
Community Manager
Hello Radhika.k,
We will help you with this inquiry in your original thread found in https://communities.intel.com/thread/105988 https://communities.intel.com/thread/105988.
-Peter.
