Community
cancel
Showing results for
Search instead for
Did you mean:
smeel
Reg:Support for edison from yocto
Hi Everyone.
I want to customize /add some features and functionality to the kernel and BSP.
I want to build an image from yocto which supports the Intel Edison board. I used this link for using krogoth https://www.yoctoproject.org/downloads https://www.yoctoproject.org/downloads and used the command git clone -b krogoth git://git.yoctoproject.org/poky.git and after the clone has done i have gone through the directories of meta, meta-yocto to see the conf.
In the conf files I have seen the machine where I am unable to see the machine as edison. After cloning I have read the README.hardware where I could see that it is supported only for beaglebone and other boards but not Edison.
I can see that the emulator is supported for x86 (edison board) . Can I know weather this poky will supoport the edison board??
I am unable to download the source code but can follow the compilation steps. /message/253475# 253475 https://communities.intel.com/message/253475# 253475
https://software.intel.com/en-us/node/593592 https://software.intel.com/en-us/node/593592 ,https://software.intel.com/en-us/node/593591 https://software.intel.com/en-us/node/593591
Srujani
Community Manager
Hello srujani,
Even if the latest version of Yocto does support x86 architectures, it must be compatible with all the following documents in order to support Edison:
${TOPDIR}/../poky/meta \
${TOPDIR}/../poky/meta-intel-edison/meta-intel-arduino \
${TOPDIR}/../poky/meta-intel-edison/meta-intel-edison-bsp \
${TOPDIR}/../poky/meta-intel-edison/meta-intel-edison-distro \
${TOPDIR}/../poky/meta-intel-iot-devkit \
${TOPDIR}/../poky/meta-intel-iot-middleware \
${TOPDIR}/../poky/meta-java \
${TOPDIR}/../poky/meta-oic \
${TOPDIR}/../poky/meta-openembedded/meta-filesystems \
${TOPDIR}/../poky/meta-openembedded/meta-networking \
${TOPDIR}/../poky/meta-openembedded/meta-oe \
${TOPDIR}/../poky/meta-openembedded/meta-python \
${TOPDIR}/../poky/meta-openembedded/meta-ruby \
${TOPDIR}/../poky/meta-openembedded/meta-webserver \
${TOPDIR}/../poky/meta-yocto \
${TOPDIR}/../poky/meta-yocto-bsp \
The Edison specific documents have not yet been implemented for krogoth and currently the latest version they support is Yocto 1.7.3 Dizzy.
-Peter.
smeel
Thanks Peter for your immediate reply.I have compiled the Yocto dizzy 1.7.3 but i could'nt find the steps to flash. and in the reference manual of yocto i could see that i can go with bitbake core image stato Yocto Project Reference Manual can u please provide the steps to flash and the referance manual for the flashing process.
M.Stujani
Community Manager
If you have successfully built the image and ran the script ../poky/meta-intel-edison/utils/flash/postBuild.sh, you will find the resulting image in the directory …/build_edison/tmp/deploy/image.
The files there can flashed into your board with any of the flashing methods, like flashall.sh or Flash Tool Lite.
-Peter.
smeel
Thanks Peter,
The thing after the compilation has done I have files as the below.where I cannot find the meta-intel-edison and searched for the images at location poky/build/tmp/deploy/images/qemux86 where I have files called as
skakarla@PCSLAPTOP-004:~/dizzy_1.7.3/poky/build/tmp/deploy/images/qemux86$ ls
bzImage
bzImage--3.14.29+git0+6eddbf4787_f6aa7aaca8-r0-qemux86-20160718061805.bin
bzImage-qemux86.bin
core-image-minimal-initramfs-qemux86-20160718122222.rootfs.cpio.gz
core-image-minimal-initramfs-qemux86-20160718122222.rootfs.manifest
core-image-minimal-initramfs-qemux86.cpio.gz
core-image-minimal-initramfs-qemux86.manifest
core-image-sato-qemux86-20160718061805.rootfs.ext3
core-image-sato-qemux86-20160718061805.rootfs.manifest
core-image-sato-qemux86-20160718061805.rootfs.tar.bz2
core-image-sato-qemux86.ext3
core-image-sato-qemux86.manifest
core-image-sato-qemux86.tar.bz2
modules--3.14.29+git0+6eddbf4787_f6aa7aaca8-r0-qemux86-20160718061805
modules--3.14.29+git0+6eddbf4787_f6aa7aaca8-r0-qemux86-20160718061805.tgz
modules-qemux86
modules-qemux86.tgz
README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
Then I have used the flash too lite and then tried to flash the image core-image-minimal-initramfs-qemux86.cpio.gz where I have got an error as there is no image to flash.
Can you please tell me where I have done the mistake.
Srujani
Community Manager
I believe you might have followed the instructions to build a vanilla Yocto build and therefore exclude the files required for Edison. I'd suggest you to follow the steps in http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html.
Also, could you please let us know the steps you followed?
-Peter.
