Community
cancel
Showing results for
Search instead for
Did you mean:
RKasu
Reg:The soft reset of Intel edison board
Hi all,
I would like to know about soft reset the intel edison (arduino expansion board),I know reboot(hard reset).My idea is to reboot only some services or processes not the whole edison board.
we are using different I2C sensors and we want to reboot only the i2c sensors without rebooting the whole edison board.This is because when we are running the I2C sensors all at a time by using external power supply only,when we are disconnecting or adding some of the sensors they are not responding immediately i.e,the devices addresses are not detecting according to the device,when we reboot the board they can be detected .But we don't want to reboot frequently as we are using some network configuration files and they will be lost if we reboot by the hardware.
we tried to kill the processes after the process is completed but I think killing the process is not the right option without rebooting.
Here the sensors are optional,but for any other operation how can we reboot only some processes without rebooting the whole edison board???Hope the answer would be useful.Any or every reply is appreciated.
Thanks and Regards,
Radhika.
Community Manager
Hi Radhika,
If you wish to restart a service in the Edison you can use systemctl. In the Edison, you can look at the services with ls /lib/systemd/system. To restart a service type systemctl restart .
Let us know if this approach works for you.
-Sergio
RKasu
Hi Sergio,
Thanks for the reply,I have my script file in /home/root/demo/edison_script.sh and created the service in ls /lib/systemd/system and my service file consists of
[Unit]
Description=edison_script.service
After=network.target
[Service]
ExecStart=/home/root/demo/edison_script.sh
Restart=always
[Install]
WantedBy=multi-user.target
As I'm using the I2C commands in the script file,I have tried the way to kill the process by the command
sudo kill -9 `ps | grep edison_script.sh | awk '{print $1}'` and the process is killed after that restarting the service using
systemctl daemon-reload
systemctl restart edison_script.service
systemctl status edison_script.service
but the status of my service is failed and is inactive(dead) although it is running in the other terminal.Even I tried without killing the process the status is that it is not loaded.
The edison_script file consists of
# ! /bin/sh
echo "I2C script"
echo 28 > /sys/class/gpio/export|echo 27 > /sys/class/gpio/export|echo 204 > /sys/class/gpio/export| echo 205 > /sys/class/gpio/export |
echo 236 > /sys/class/gpio/export |echo 237 > /sys/class/gpio/export|echo 14 > /sys/class/gpio/export |echo 165 > /sys/class/gpio/export| echo 212 > /sys/class/gpio/export|echo 213 > /sys/class/gpio/export |echo 214 > /sys/class/gpio/export |
echo low > /sys/class/gpio/gpio214/direction|echo low > /sys/class/gpio/gpio204/direction | echo low > /sys/class/gpio/gpio205/direction |
echo in > /sys/class/gpio/gpio14/direction|echo in > /sys/class/gpio/gpio165/direction|echo low > /sys/class/gpio/gpio236/direction| echo low > /sys/class/gpio/gpio237/direction|echo in > /sys/class/gpio/gpio212/direction |echo in > /sys/class/gpio/gpio213/direction|
echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux |echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux|
echo high > /sys/class/gpio/gpio214/direction
i2cdetect -r 6
I'm not knowing how to approach to my problem.Is there any way to approach to soft reset.Are there any changes in the service file in system.??Or should I go for another Service in /lib/systemd/system?If I should go to another service ..which service for I2C should be restarted.??Can I configure GPIO pins to restart the process??(not only for I2C)
Please let me know the process to soft reset the edison only for some processes without effecting the other files in edison.Hoping the positive result from you.
Thanks and Regards,
Radhika.
Community Manager
Could you try to run the systemctl commands one by one to check if each individual command is working as expected? While the service is running, use systemctl status unit to check if it's on. Then, reload the service. You can check the various options here https://www.freedesktop.org/software/systemd/man/systemctl.html https://www.freedesktop.org/software/systemd/man/systemctl.html . Try with systemctl reload unit and systemctl daemon-reload options. After each, check with the systemctl status unit option again to see if the service restarted successfully. You can post screenshots of systemctl status unit output after each command is entered to see how the service is behaving. Once you confirm you're using the right commands you can add the systemctl commands to the edison_script.sh file.
We'll be waiting for your response.
-Sergio
RKasu
Hi Sergio,
Yes,I have tried the systemctl commands individually and I'm seeing the same error again ...I'm pinning the screenshots below..
My service file consists of
[Unit]
[Service]
Restart=always
[Install]
My edison_script.sh file has
# ! /bin/sh
echo "I2C script"
i2cdetect -r 6
Thanks and Regards,
Radhika
Community Manager
Hi Radhika,
While researching for this case I noticed you have another thread opened that discusses the same issue. I'd suggest for you to continue with support in /thread/105293 https://communities.intel.com/thread/105293 .
This is done to avoid confusion and threads with duplicate information.
-Sergio
