Community
cancel
Showing results for
Search instead for
Did you mean:
RKasu
Regarding I2C lines interfering with GPIO
I'm using intel edison arduino expansion board.I'm using GPIO's 8,9,10 on edison and these are connected to other devices .when I'm triggering I2C lines ,the GPIO's are becoming low.The default value for the GPIO's is high.When the I2C lines are triggered ,the GPIO's are becoming low,therefore the devices connected to GPIO's are also becoming ON.I have added 10K ohm resisters to GPIO's but the issue is not resolved.
Can you please suggest me the neccesary inputs.Please do needful.
Thanks and Regards,
Radhika
Community Manager
Hi Radhika,
Thank you for contacting us. Your goal seems to be the same as here: /thread/116681 https://communities.intel.com/thread/116681 . We'll close this case and continue to help in the aforementioned thread to avoid confusion and have all the relevant information about your request in a single thread.
-Sergio A
