Community
cancel
Showing results for
Search instead for
Did you mean:
RKasu
Regarding the Intel edison configuration tool
Hai everyone,
I'm very new to the technology,I'm using the latest yocto image with 3.10.98 version.I'm using the intel edison arduino board.I'm trying to connect the edison through wifi using Intel edison configuration tools.,but at the time of seeting up the password ,it is unable to change the password.Even I tried with the different length of passwords,but the password is necessary inorder to connect to wifi.So,anyone please help me out of it.I'm pinning the screenshot below.
Thanks and Regards,
Radhika
Community Manager
Hi Radhika,
Do you already have access to your Edison's serial console? If so, you can set the password with by establishing a serial connection. Once connected you'll just have to run configure_edison --password, you'll then be prompted to assign a password for your Edison. If you want to run all the setup process (which includes setting the Edison's name, password and WiFi) you can run configure_edison --setup.
-Pablo
Community Manager
Hi Radhika,
Do you have updates on this case?
-Pablo
