Community
cancel
Showing results for
Search instead for
Did you mean:
JSh
Rename wlp1s0 to wlan0
Sketch "ScanNetworks" print "WiFi shield not present".
I suspect that because my wifi (Intel 135) is certain as wlp1s0, and the standard name is wlan0.
ifconfig -a
wlp1s0Link encap:Ethernet HWaddr UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
connmanctl:
connmanctl> technologies
/net/connman/technology/ethernet
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
/net/connman/technology/bluetooth
Name = Bluetooth
Type = bluetooth
Powered = False
Connected = False
Tethering = False
/net/connman/technology/wifi
Name = WiFi
Type = wifi
Powered = True
Connected = False
Tethering = False
connmanctl> enable wifi
Error wifi: Already enabled
connmanctl> services
*AO Wired ethernet_************_cable
How I can rename wlp1s0 to wlan0?
Sergio_A_Intel
Are you trying to connect through Ethernet or through WiFi because your connmanctl output says connected=true for your Ethernet interface. Also, what image are you using, on the Yocto image the default name is wlan0. Is the interface not working correctly or you just want to change the interface name?
What steps or guide have you followed to set up your Galileo's internet connection?
Sergio
JSh
Thank you for your answer.
After I downloaded the new image all worked fine.
But Linux have not commands to rename network interface?
Sergio_A_Intel
Yes, there are Linux commands that will help you change the interface name. Take a look at this methodhttp://www.cyberciti.biz/faq/howto-linux-rename-ethernet-devices-named-using-udev/ Linux Rename Eth0 Network Interface Card Name [ Udev ] . To change the interface name with this method you need the udev manager. You can get it for galileo in http://repo.opkg.net/galileo/ Index of /galileo following the steps from http://alextgalileo.altervista.org/package-repo-configuration-instructions.html Galileo Package Repo Configuration Instructions
Sergio
Jian_Z_Intel
could you tell me where you download the image
Sergio_A_Intel
You can download it here: http://www.intel.com/support/galileo/sb/CS-035101.htm Intel® Galileo Boards — Software Downloads
Sergio
