Intel® Makers
9869 Discussions
Replace C90 to C99 compiler in Intel® System Studio for Microcontrollers
BZiol
Hi Intel,
Is there option to replace C90 to C99 compiler in Intel uC Studio? Do you support it?
Kind regards,
Bartosz
avijit.M
AdrianBurns
Arun_P_Intel
Bartosz,
The default mode for C in GCC 5 release series (in ISSM) is gnu11 (C11). So wondering where C90 comes from. Why are you looking to move to C99?
Arun_P_Intel
Bartosz,
bbogu1
I have the same problem and noticed this flag while compiling sources:
i586-intel-elfiamcu-gcc -DPRINTF_ENABLE -DPUTS_ENABLE -O0 -g -DDEBUG -std=c90 -Wall ...
is it possible to set this flag to c99?
Thanks, Bartek
avijit.M
AdrianBurns
BZiol
Problem solved. You need to change flag in base.mk file:
CFLAGS += -std=c90 -Wall -Wextra -Werror -Wno-unused-parameter
to
CFLAGS += -std=c99 -Wall -Wextra -Werror -Wno-unused-parameter
And there is no option to add, modify compiler settings via ISSM environment...
Bartosz
avijit.M
AdrianBurns
