Intel® Makers
9872 Discussions
Reset button bug with sd card image
SArbo
Hi, I've created and booted my Intel galileo gen 2 from an image on a bootable micro SD card as is shown here: https://software.intel.com/en-us/programming-blank-sd-card-with-yocto-linux-image-windows Making a bootable micro SD Card with Windows* . I want to use Arduino software to develop my sketches and I followed all the steps in the arduino guide. I can run sketches in my board, nevertheless everytime i pushed the reset button, the sketch crash and it won't reset, to solve this and run the sketch again i have to reboot the board. How can i fix this?
Diego_V_Intel
Hello sebaz_143,
I recommend you to use the following SD Yocto image: http://downloadmirror.intel.com/24355/eng/SDCard.1.0.4.tar.bz2 http://downloadmirror.intel.com/24355/eng/SDCard.1.0.4.tar.bz2. In order to use this Yocto image, you only need to decompress the files and copy them into the SD card root directory. Please check the following site where you can find a step-by-step guide to set up this Yocto image: http://www.intel.com/support/galileo/sb/CS-035033.htm Intel® Galileo Boards and Kits — SD Card Setup and Sketch Persistent
Once you have set up the SD card with this image, try to reset an Arduino sketch again. You shouldn't have any issues with it.
Diego.
Diego_V_Intel
Hello sebaz_143,
Diego.
FTinetti
Honored Contributor I
Just a minor detail: take into account the differences between both Yocto versions: the one you have used and the one recommended by Diego.
The one you have used is intended to be used with XDK: "You can boot your Intel® Galileo board using a micro SD card that contains the latest Intel® IoT Developer Kit version of the Yocto* built, Linux image."
The one recommended by Diego is the good one, I think, for the purpose you have described: Arduino sketch persistency.
HTH,
Fernando.
SArbo
I'm going to try it and I let you know, thank you so much.
SArbo
Thank you so much Diego and FGT it works perfect!
