Community
cancel
Showing results for
Search instead for
Did you mean:
CWern1
Resolution and Overscan issues
Jump to solution
I am using the BOXSTKAW32SCR Compute Stick with the same scaling/over-scan issues. I updated the firmware and HD Graphics drivers to the most current. Using the Custom Resolution in the Intel HD Graphics Control Panel, I am unable to set the resolution to 1366 x 768 with Underscan equal to 5%. I get the error message "An invalid value has been entered. Refer to the manufacturers manual to determine the supported values for the display". What am I doing wrong?
Chris
Community Manager
Hello chriswer,
Thank you for joining the Intel communities.
I can confirm the same error but I used more percentage 10 and it works or I used 3% or 2% and it works as well.
Would it be possible for you to try different percentage?
Ivan
Community Manager
Hello chriswer,
Ivan
CWern1
Issues resolved after trying 10%. Works great now!
Community Manager
I'm glad that your issue has been resolved and thank you for letting me know that the information provided solved the issue.
Best wishes,
Ivan
