Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Resource Path Location Type passing argument 3 of 'qm_gpio_read_pin' makes pointer from integer without a cast [-Werror=int-conversion] main.c /LED_Blink line 41 C/C++ Problem
Jump to solution
I wrote this code,when I press the button I want to put the outputs at 1 after a predefined delay in this case 0.25 seconds.
I have this error that I´m trying to solve but for that I need your help.
At line 41 # define BUTTON 2 - error ( passing argument 3 of 'qm_gpio_read_pin' makes pointer from integer without a cast [-Werror=int-conversion] )
and at Line 93 and 106 i have this warnings: in expansion of macro 'BUTTON'
I appreciate the help.
MFF
Accepted Solutions
Highlighted
Community Manager
Hi MFF,
It seems that you posted your issue again in the following thread: , we are going to continue supporting you in that thread to avoid confusions.
Have a nice day.
-Leonardo
Highlighted
Community Manager
Hi MFF,
Have a nice day.
-Leonardo
