Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Restarting sketch
Jump to solution
Is there a way to restart sketch from the sketch itself? Some system call or similar?
Thanks in advance
Accepted Solutions
Highlighted
Re: Restarting sketch
Jump to solution
Hello justRadojko,
What I can think of is that you could make a call to system() and reboot, it would look like this:
system("reboot");
All the other methods I've found that uses Arduino, call AVR libraries, which is the architecture of Arduino and therefore, will not work on the Galileo.
Peter.
Highlighted
1 View
Jump to solution
Hello justRadojko,
system("reboot");
Peter.
