Intel® Makers
9874 Discussions
Run a program on background
hdong5
Hi All,
I understand that "nohup python xxx.py" can run a python script on background in Linux system.
But when I use "nohup python xxx.py" in yocto linux, it seem as follow:
root@edison:~# nohup xxxxx.py
nohup: appending output to nohup.out
Then it don't allow me to go back to the terminal until the end of program.
I am wondering how can I run the script on background and then go back to the terminal, so that I can run other programs.
Many thanks
Hao
Carlos_M_Intel
Hi hao,
Hi you can use python xxx.py &
In order to stop it you will need to run the command ps and check the PID for python xxx.py, for example if the PID is 283, in order to stop the script you will need to run kill 283
Charlie
Carlos_M_Intel
Hi hao,
Charlie
hdong5
