Community
cancel
Showing results for
Search instead for
Did you mean:
REdwa1
Running DS1307 RTC over an Intel Edison on Sparkfun blocks
Jump to solution
My project is based on Sparkfun's Edison breakout blocks, and I need to get the DS1307 RTC speaking to it via the I2C Block. I've not found any guides specifically for Edison here, but found a http://www.switchdoc.com/2014/07/python-driver-ds1307-real-time-clock/ Raspberry tutorial (with https://github.com/switchdoclabs/RTC_SDL_DS1307 library in github) that looks usable or adaptable. I've connected the DS1307's SDA/SCL pins to the I2C block, its GND/5V pins to a 5V power supply, and I2C block's GND to the 5V supply ground. Next I installed the SMbus library with `opkg install python-smbus`, and cloned the Raspberry library and called the test script:
root@edison:~/rtc/RTC_SDL_DS1307# python testSDL_DS1307.py Test SDL_DS1307 Version 1.0 - SwitchDoc Labs Program Started at:2016-01-18 17:22:29 [ 1650.236006] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration Traceback (most recent call last): File "testSDL_DS1307.py", line 35, in ds1307.write_now() File "/home/root/rtc/RTC_SDL_DS1307/SDL_DS1307.py", line 200, in write_now self.write_datetime(datetime.now()) File "/home/root/rtc/RTC_SDL_DS1307/SDL_DS1307.py", line 194, in write_datetime dt.isoweekday(), dt.day, dt.month, dt.year % 100) File "/home/root/rtc/RTC_SDL_DS1307/SDL_DS1307.py", line 157, in write_all self._write(self._REG_SECONDS, _int_to_bcd(seconds)) File "/home/root/rtc/RTC_SDL_DS1307/SDL_DS1307.py", line 83, in _write self._bus.write_byte_data(self._addr, register, data) IOError: [Errno 11] Resource temporarily unavailable
The script fails on the second of these lines:
ds1307 = SDL_DS1307.SDL_DS1307(1, 0x68) ds1307.write_now()
Not sure why it fails. Very grateful for assistance. The following calls will help explain what's going on on the I2C bus.
root@edison:~/rtc/RTC_SDL_DS1307# i2cdetect -y -r 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- root@edison:~/rtc/RTC_SDL_DS1307# i2cdump 1 0x68 w WARNING! This program can confuse your I2C bus, cause data loss and worse! I will probe file /dev/i2c-1, address 0x68, mode word Continue? [Y/n] Y 0,8 1,9 2,a 3,b 4,c 5,d 6,e 7,f [ 830.245731] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration 00: XXXX ff1f XXXX XXXX XXXX XXXX XXXX XXXX [ 830.253809] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.254463] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.259504] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.266452] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.267940] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.272002] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.272209] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.272410] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.280218] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.286532] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.289284] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.290893] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.299010] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration [ 830.305487] i2c-designware-pci 0000:00:08.0: i2c_dw_handle_tx_abort: lost arbitration 08: XXXX ff4f XXXX XXXX XXXX XXXX XXXX XXXX 10: ff6f XXXX XXXX XXXX XXXX XXXX XXXX XXXX 18: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 20: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 28: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 30: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 38: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 40: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 48: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 50: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 58: ff0f XXXX XXXX XXXX XXXX XXXX ff83 XXXX 60: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 68: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 70: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 78: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 80: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 88: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 90: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX 98: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX a0: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX a8: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX b0: XXXX XXXX XXXX XXXX XXXX XXXX ff1b XXXX b8: ff0f ff43 XXXX XXXX XXXX XXXX XXXX XXXX c0: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX c8: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX d0: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX d8: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX e0: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX e8: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX f0: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX f8: XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX
REdwa1
Problem solved in this case by:
- extending the circuit to include the Sparkfun Fuel Gauge, and
- de-soldering the RTC's ST2 jumper that connects to the pull-up resistor (since the Fuel Gauge features this),
- cutting the jumper to 3.3V on the I2C block - https://cdn.sparkfun.com/assets/learn_tutorials/3/1/1/5Vhack.png https://cdn.sparkfun.com/assets/learn_tutorials/3/1/1/5Vhack.png
Now the RTC Module responds for voltages above 4V.
VIvan7
New Contributor III
I²C in the Edison is 1.8V. You need a level translator.
The Edison has a built-in RTC. It just needs a battery connected to the V_VBAT_BKUP pin. I think it should be >= 2.7V and <= 3.3V.
REdwa1
Hi Vincenze. The RTC is running on an independent 5V supply. And like I say I'm using Sparkfun Blocks - unfortunately none of these provide access to the V_VBAT_BKUP pin or that would certainly be the best solution..
Sergio_A_Intel
This might be related to the voltage values needed by the shield and given by your board. The Arduino expansion board's I/O can be set to 3.3V or 5V depending on J9. In what position do you have J9? Is there any chance you can connect a logic analyzer to the shield's power and data signals to see if the signal is not being distorted?
Sergio
REdwa1
Hi Alvarado - what do the Sparkfun blocks have to do with Arduino? Am I missing something? https://www.sparkfun.com/categories/272 Intel® Edison - SparkFun Electronics
VIvan7
New Contributor III
Just make a board for an RTC chip that works at 1.8V. There are many.
I quickly googled:
http://ww1.microchip.com/downloads/en/DeviceDoc/25010A.pdf http://ww1.microchip.com/downloads/en/DeviceDoc/25010A.pdf
http://www.nxp.com/documents/data_sheet/PCF85063A.pdf http://www.nxp.com/documents/data_sheet/PCF85063A.pdf
Or use an I²C level translator chip 1.8V<->5V. You need an open-drain level translator. There are also many.
REdwa1
Thanks Vincenze, your comment made us review the configuration and spotted we needed to adapt the RTC as I've described. So thank you
REdwa1
