Intel® Makers
9873 Discussions
SPI DMA Mode patches and latest IOT release (20160606)
MPapi
Has anyone had any success in getting the SPI DMA patches to build into a usable kernel/ image?
Background:
As we all know SPI on Edison has some "issues" and at this point, I've lost track of what all of them are, but I can say that I have more success bit-banging than using the hardware SPI, and that's pretty sad. I stumbled across Primiano's patch set (https://github.com/primiano/edison-kernel.git GitHub - primiano/edison-kernel: Kernel (v3.10.17 + Intel patch) for Intel Edison IoT module ) and subsequently drcrallen's Yocto layer to implement them (https://github.com/drcrallen/meta-primiano-dma.git GitHub - drcrallen/meta-primiano-dma: Bitbake recipes for @primiano's dma patch set ). I have been unable to successfully build for a number of reasons, all of which boil down to my own inability to understand Yocto and the current source release structure.
What I Have Tried:
1) Incorporating drcrallen's layer directly into the build_edison/conf/bblayers.conf. Having performed all of the sanity checks that I know, it seemed to fit in there, however, a simple re-invocation of bitbake edison-image uboot resulted in nothing much happening ... perhaps somebody knows the incantation that I should be using to at least get a little bit further.
2) In a fit of suicidal dementia, I tried applying the patch sets by hand - I highly recommend against this for the sake your own personal sanity ... the patch sets had some conflicts (or I created some -yet to be understood), that I gave a good try at resolving and again re-launched bitbake, which proceeded to overwrite the lovingly modified files (which I had luckily backed up). I have little hope in this working since the patch sets are massive and the probability that I did all of the changes correctly is vanishingly small...
3) creating a do_unpack() that simply copied over the code from 2) above, into the source directory, but a subsequent do_patch() which I have yet to track down fails subsequently saying that some files don't match the index ...
What I'm asking:
Has anybody been able to get this to work? If so, how? Does anybody know what incantation I should use in attempt 1) above, to get a bit further?
Any help, support or indications would be most welcome ... barring great insights, I'll just go back to the version that was used by drcrallen.
As a final question addressed at Intel, why weren't these patches included in the latest release since they have been in the wild for over a year???
Mario.
MPapi
Well, my conclusion is that the new kernel is just not worth it.
Instead I am running Primiano's kernel directly and have modified my linux-externalsrc.bb to build directly out of primiano's git. This works for me at 25 MHz on SPI. Until Intel decides to include patches that are publicly available, I have no real choice. Attached, for anyone that would like seemingly functional SPI (seemingly because my testing thus far is limited) , I have attached my linux-externalsrc.bb. As a matter of interest, this could be similarly modified to build other kernels directly into the image. A big thanks to Primiano and drcrallen for having blazed a trail that, for me at least, has been useful and helpful.
Mario.
MPapi
Mario.
