Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SPI calling from other Library
I'm trying to compile this Sketch on a Simatic IOT2020 but during the compiling I get some issues:
Code:
# include
# include
int counter = 0;
void setup() {
Serial.begin(9600);
while (!Serial);
Serial.println("LoRa Sender");
if (!LoRa.begin(915E6)) {
Serial.println("Starting LoRa failed!");
while (1);
void loop() {
Serial.print("Sending packet: ");
Serial.println(counter);A
// send packet
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
delay(5000);
Issues:
In file included from C:\Users\hladik\Desktop\arduino-1.8.2\LoRaReceiver\LoRaReceiver.ino:2:0:
C:\Users\hladik\Documents\Arduino\libraries\LoRa\src/LoRa.h:74:3: error: 'SPISettings' does not name a type
Link to Library:
https://github.com/sandeepmistry/arduino-LoRa/tree/master/src arduino-LoRa/src at master · sandeepmistry/arduino-LoRa · GitHub
Could somebody help me with this?
By the way: when I compile it for a Arduino Mega 2560 everything runs propertly.
Community Manager
Hello MerlinHladik,
Thank you for your interest in the Intel® Galileo Board.
I am not familiar with the SIMATIC IOT2020, I visited the manufacturer's site and noticed the compatibility with the Arduino IDE and Arduino shields.
Could you please tell me how you are using the Galileo Board in your project?
You mentioned that the code compiles in the Arduino Mega 2560, but there is a chance that the reason behind the error message may be due to an incompatibility issue.
I checked the technical specifications of the SIMATIC IOT2020 and noticed that it uses an Intel Quark SoC X1000 CPU, while the Arduino Mega 2560 board is microcontroller based (ATmega2560). Due to this difference, not every library can be used in both systems.
I'll be waiting for your response.
Have a nice day.
Andres V.
Community Manager
Hello Andres V.
I found it out already.
In the SPI.h library that is used for the Intel galileo gen2 is the function SPISettings() missing.
I got this library by downloading the packet for Intel i586 Boards in the Board Manager in the Arduino IDE.
But anyway, thanks for your quick response.
Best Regards
MerlinHladik
Community Manager
Hello MerlinHladik,
I'm glad to hear that you could solve the issue.
Thank you for sharing your experience with the community, we really appreciate it.
Have a nice day.
Andres V.
