Intel® Makers
SSH and SFTP
akuma85
How to use SSH and SFTP in edison. Any guide would be helpful.
Community Manager
Hello arunkumark,
Thanks for reaching out!
In order to use SSH or SFTP you need to set up a password on your Edison and set up Wi-Fi. You can do both by entering the command configure_edison --setup and following the instructions.
Once that is set up, you should be able to use SSH or SFTP.
You can follow this guide: https://learn.sparkfun.com/tutorials/edison-getting-started-guide# ssh-ing-into-the-edison in order to connect to your Edison through SSH.
In order to use SFTP on your Edison, you will have to install a package called openssh-sftp. This package is found on the official repo and can be installed with the command:
opkg install openssh-sftp
In http://linux.die.net/man/1/sftp, you will be able to find details about how to use this package.
I hope this information helps you,
Pedro M.
Community Manager
Hello arunkumark,
Pedro M.
