So my experience with STK1A32WFC and STK2m364CC was fine and Linux runs perfect, I buyed the STK1A(W)32SC, due to the out of the box supported WLAN/BT Chipset. See also my comments in this thread: /thread/106904 https://communities.intel.com/thread/106904
At first I updated the BIOS to the new v0030 for STK1A32SC and STK1AW32SC (marked as the same - which make sense due to the identical HW). But it is not possible with this version to access via Linux (e.g. openSUSE Tumbleweed build from 26.12.2016) the microSD Card. Also an in the STK1A32WFC installed mikroSD Card, which is working fine also with the STK2m364CC, won't be listed as boot device in the BIOS settings (F2) or the Boot Menu (F10). In the documentation I can't find any deviation, between the 3 Compute Sticks! So I expect this is a bug in the BIOS firmware.
Some additional issues I've detected in the BIOS:
Happy New Year
UbIx
Hello UbIx ,
When the Intel® Platform Trust Technology (Intel® PTT) is switch on is a platform functionality for credential storage and key management used by Windows 8* and Windows® 10. Intel® PTT supports BitLocker* for hard drive encryption and supports all Microsoft requirements for firmware Trusted Platform Module (fTPM) 2.0.
The Intel Compute Stick STK1AW32SC has Windows 10 Home 32-bit pre-installed with all necessary drivers, 64bit is not supported. On this unit any other operating system, Linux*, OpenSUSE we don't support it, this is because it has not been validated by Intel, you will get better support for these distros from their forum support sites.
The unit has been build to work with Windows®10 so legacy mode will not be necessary for the unit because older Windows® version is not supported and Windows®10 works better with UEFI.
You can see supported operating system here:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005899.html http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005899.html
Now, if somebody else has been able to install and access the Micro SD, they are free to share that information with us.
If the Micro SD is not detected not even with Windows installed, this could be an issue either with the Micro SD Card Reader or with the Micro SD itself, but in this case you're mentioning that the card works with the other Intel® Compute sticks.
Do you have another Micro SD to try if it is possible if not that is understandable?
What is the size of the Micro SD Card? It is formatted in exFAT or FAT32? Either one should work but is just to try. What is the model of the card?
Ivan.
Hi intel_corp Ivan,
at first - thanks for your fast reply
Intel Corporation wrote:
Hello UbIx,
Thanks for your information. In the future it can be helpful if this information is available in the BIOS itself if I press F1-key
Sure, that's clear - that I do this with my own risk (like always if I need Linux). Normally I would by the STK1A32SC - but this is not in all shops available and the price deviation is sometimes only some Euro - so that I used a shop which I do anyway a buy - so the price deviation was covered by the transportation fee. But on this - there is now remark that I lost the warranty, if I play Linux on it . So for me it is not forbidden (hopefully).
Sure - this is always the situation at all companies
Hopefully - someone can help
Yes, I can read the card on the preinstalled Windows (for sure only the FAT-UEFI part of the card). But at boot time and also later after boot, I can't see the bootable source. I use the quality cards from SanDisk Ultra (32GB and 64GB) or Samsung Pro (32GB), both shows the same effect on STK1AW32SC (but all works fine in the other both Compute Sticks STK1A32WFC and STK2m364CC). So for me es electronic Engineer, it looks like an error on the BIOS of the STK1A(W)32SC. So the BIOS have many additional bugs like written above (much more than the other both C-Sticks)
Like written above, I tested two different Suppliers (SanDisk and Samsung) and two different Card-Sizes (32GB and 64GB). All I can read with the preinstalled Windows fine (for sure only the supported File Systems). But doesn't be detected in the internal slot.
One partition is formatted with the EFI-FAT
The Installation partitioning with the Linux
Device Boot Begin End Sectors Size Kn Typ
/dev/sdh1 3840 11399 7560 3,7M ef EFI (FAT-12/16/32)
/dev/sdh2 * 11400 9091071 9079672 4,3G 17 Hidden HPFS/NTFS
And the later generated one (32GB => 29GB) which was generated on STK1A32WFC and works fine on this one:
/dev/sdi1 2048 321535 319488 156M EFI-System
/dev/sdi2 321536 643071 321536 157M Linux-Filesystem
/dev/sdi3 643072 4868095 4225024 2G Linux-Filesystem
/dev/sdi4 4868096 62519295 57651200 27,5G Linux-Filesystem
The EFI partition is the relevant part for the BIOS - which includes the bootloader of the Linux system.
Summary: for me it looks like, the enabling of the SD-Card interface don't work really in v0030!
UbIx
EDIT: It seems that the Editor here can't handle multiple quotes in one answer correctly (in the Editor view it looks perfect).
I really appreciate your feedback about the F1-key and thank you for all the information.
Does this SD-card work on previous BIOS version with the Intel® STK1AW32SC?
Perhaps you would like to try version https://downloadcenter.intel.com/download/26317/BIOS-Update-SCCHTAX5-86A-?product=91065 0029 and see how it goes.
Also, I would suggest to post your issue at the Linux*community to see if somebody else can be able to help somehow.
We are always working to make better our products so any feedback is appreciated, hopefully new BIOS versions will be released to add features and fix issues.
Ivan.
Hi Ivan (intel_corp ),
thanks for your reply.
I will test the roll back of the Firmware tomorrow. For some minutes I've tested to disable/enable the internal SD-Card support in BIOS - but no effect.
UbIx
Hi Ivan,
Perhaps you would like to try version https://downloadcenter.intel.com/download/26317/BIOS-Update-SCCHTAX5-86A-%3Fproduct%3D91065 0029 and see how it goes.
I tested the recovery via F4 and the reflashing with the v0029, both don't work.
Is it possible that the recovery don't work if the update was done via Windows?
Additional I made some many other tests - it is not possible to access the SD-Card without Windows drivers
Per default the event logging is on and some crazy entries are in - do you think this was OK:
CMOS Checksum Error ( 2) 3/27/2048 0: 0: 0
CMOS Time Not Set ( 2) 1/ 1/2015 0: 0: 0
Flash Update Failed ( 8) 10/27/2025 20:12:42
The entry with the BIOS update is missing and also the time was from beginning on OK (I think due to the Time Server in my local network - which is also included in the DHCP entry). Also I've connected an Digitus USB 3.0 3-Port HUB & Gigabit LAN Adapter DA-70250:
http://www.digitus.info/en/products/computer-accessories-and-components/computer-accessories/usb-hub... http://www.digitus.info/en/products/computer-accessories-and-components/computer-accessories/usb-hub...
Which works fine with all compute sticks with Windows 10 and Linux (out of the box without driver installation).
What is confusing for me, is the fast reboot without any text output, if I start the Recovery with F4 - on the STK1A32WFC there was an dialog which ask me if I was sure - to do this (I don't remind the correct wording anymore).
A totally confused
UbIx
Maybe I posted the incorrect BIOS version, please try this version for the Intel® Compute Stick STCK1A32WFC
https://downloadcenter.intel.com/download/26502/BIOS-Update-FCBYT10H-86A- https://downloadcenter.intel.com/download/26502/BIOS-Update-FCBYT10H-86A-
This version is latest one that Intel has released
Ivan.
Hi Ivan,
thanks for the replay. But I don't need an update on STCK1A32WFC - which is running fine with Linux on the SD-Card.
I need to update the STK1AW32SC, which the newest BIOS is there:
https://downloadcenter.intel.com/download/26448/BIOS-Update-SCCHTAX5-86A-?v=t https://downloadcenter.intel.com/download/26448/BIOS-Update-SCCHTAX5-86A-?v=t
But anyway, I flashed now 0029 and again 0030, but still the SD card won't be listed, also not with the FAT FS which includes the firmware files. With a stick and also with a sd card reader which includes this SD card, it is possible to read!
Thanks for this information, if you are able to read the SD card from a SD card reader then it seems that the Intel® Compute Stick card reader is defective, at least this is what it seems to be for me.
At this point, I suggest getting a replacement for the unit.
I have sent you a private message.
Ivan.
Hi Ivan,
thanks again for answer. I've received your eMail, but I prefere to send it back to my supplier (so I'm in the 14 days extended warranty (in Germany you can send in this time each more expencive device back - also without any reason) and for sure in the half year warranty for full functionality).
But I fill the Email and send it back. If it is better - for error analysis reason, than I also accept to send it to Intel.
Please let me know your preferred solution.
UbIx
In this case, we just replace the unit but we don't do any analyze unless there is several report about the same issue.
At this point if you have the option to send it to your supplier in Germany I suggest you to get in contact with them and get the replacement.
Best wishes,
Ivan.
Hi Ivan,
OK, than I will send it back to supplier. Please ignore my private answer for some minutes.
Thanks for support and nice Day
UbIx
You are more than welcome!
Best wishes,
Ivan.
Hi Ivan,
today arrived the new STK1AW32SC - but still the same issue (in the moment BIOS v0029).
Seems for me more an BIOS issue than a HW topic.
Ulf
Does the output you get from
dmesg | grep mmc1
provide any insights into the problem?
Make sure fast boot is off in the BIOS.
Other than that I'm not sure what could've be, is not detected in BIOS either?
Is your SD model on the Intel® compatibility list, this could be also a compatibility problem with the Intel® Compute stick.
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017555.html Tested Peripherals for Intel® Compute Stick STK1AW32SC and STK1A32SC
Ivan.
Hi Repeat%20Offender,
on the STK1AW32SC only mmc0 is listed in
fdisk -l
and
dmesg | grep mmc
has no return
On my STK2m364CC (which the same Samsung Ultra Card boots - see my description above), the output of the same:
fdisk -l
and
dmesg | grep mmc
returns only an BTRFS message from installed Tumbleweed partition on the internal memory
Hopefully on weekend I can check the output on EVI console.
Here is a procedure that doesn't require installing an OS to reproduce the problem.
1. Get one of linuxium 's Zesty images, e.g. https://goo.gl/8MScR9 zesty-ubuntu-desktop-alpha-010117-linuxium.iso - Google Drive
2. Get rufus https://rufus.akeo.ie/ Rufus - Create bootable USB drives the easy way
3. Burn zesty image to 8+ GB USB stick using rufus.
4. Insert USB stick into Compute Stick (Power connected but turned off)
5. Hold power button for 3.5 sec (time with watch) and release
6. At menu, hit for boot menu
7. Select USB (make it white), hit
8. At GRUB menu, accept default of Try Ubuntu without installing
9. After ubuntu boots, hit ++T to start Terminal
10. Hit so numeric keypad works
11. I always have to type
xrandr --output HDMI-2 --mode 3840x2160 --rate 30
at this point becaues ubuntu wants to start me out in 4096x2160 so I can't see the edges of my logical display.
12. Connect to network using icon @ upper right
Here is the content of my Terminal session
[code]
To run a command as administrator (user "root"), use "sudo ".
See "man sudo_root" for details.
ubuntu@ubuntu:~$ xrandr --output HDMI-2 --mode 3840x2160 --rate 30
ubuntu@ubuntu:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 930M 0 930M 0% /dev
tmpfs 193M 9.2M 184M 5% /run
/dev/sda1 30G 2.0G 28G 7% /cdrom
/dev/loop0 1.5G 1.5G 0 100% /rofs
/cow 964M 68M 897M 7% /
tmpfs 964M 133M 832M 14% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 964M 0 964M 0% /sys/fs/cgroup
tmpfs 964M 4.2M 960M 1% /tmp
tmpfs 193M 160K 193M 1% /run/user/999
/dev/mmcblk0p5 9.6G 5.8G 3.4G 64% /media/ubuntu/2a8cc165-d07a-4feb-939b-a626131a24e0
/dev/mmcblk0p4 19G 17G 2.0G 90% /media/ubuntu/5C1E95661E9539CA
ubuntu@ubuntu:~$ blkid
/dev/mmcblk0p1: LABEL="Recovery" UUID="A6EC846DEC843A17" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="8831a3b4-a894-4ee4-92cf-3522cdeaf1d3"
/dev/mmcblk0p2: UUID="EC88-4951" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="250078dc-fd3a-4854-b23b-d89af6d21368"
/dev/mmcblk0p4: UUID="5C1E95661E9539CA" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="9e2e5047-8209-4a2b-a3be-d4325bff0d66"
/dev/mmcblk0p5: UUID="2a8cc165-d07a-4feb-939b-a626131a24e0" TYPE="ext4" PARTUUID="56e100b8-bb61-4b4a-86ea-5bff51ed1b36"
/dev/sda1: LABEL="UBUNTU 17_0" UUID="7C28-B64F" TYPE="vfat" PARTUUID="01aaa8ca-01"
ubuntu@ubuntu:~$ dmesg | grep mmc1
[ 40.573283] mmc1: SDHCI controller on ACPI [80860F14:02] using ADMA
[ 40.953164] mmc1: Skipping voltage switch
[ 43.120918] mmc1: card never left busy state
[ 43.121003] mmc1: error -110 whilst initialising SD card
[ 43.218881] mmc1: Skipping voltage switch
[ 43.677138] mmc1: Skipping voltage switch
[ 45.200171] mmc1: Skipping voltage switch
[ 47.584931] mmc1: card never left busy state
[ 47.584943] mmc1: error -110 whilst initialising SD card
[ 49.976616] mmc1: card never left busy state
[ 49.976629] mmc1: error -110 whilst initialising SD card
[ 52.439439] mmc1: Skipping voltage switch
[ 54.920977] mmc1: card never left busy state
[ 54.920989] mmc1: error -110 whilst initialising SD card
ubuntu@ubuntu:~$ mkdir /stuff
mkdir: cannot create directory '/stuff': Permission denied
ubuntu@ubuntu:~$ sudo mkdir /stuff
ubuntu@ubuntu:~$ sudo mount /dev/sda1 /stuff
mount: /dev/sda1 is already mounted or /stuff busy
/dev/sda1 is already mounted on /cdrom
ubuntu@ubuntu:~$ gedit /dev/sda1/output.txt
** (gedit:3750): WARNING **: Error when getting information for file "/dev/sda1/output.txt": Not a directory
ubuntu@ubuntu:~$ cd /dev/sda1
bash: cd: /dev/sda1: Not a directory
ubuntu@ubuntu:~$ cd /cdrom
ubuntu@ubuntu:/cdrom$ gedit output.txt
[/code]
So it can be seen what an ubuntu newbie I am, but at least some error messages seem to be showing regarding the sd card.
Ivan.
Hi Ivan,
There is no fast boot option in BIOS v0029 (update to v0030 is planed next days)!
I Tested (Like described in this thread ):
With all still the same - works stable in the STK1A32WFC and STK2m364CC (also will be listed in the Boot menu - F10 - if there is a EFI GDI System available).
UbIx
thanks for your detailed reply. But I see no dedicated reason to use not 100% free Ubuntu instead off openSUSE Tumbleweed.
Now I've installed daily build from 2016-01-18
# uname -a
Linux linux-vt4t 4.9.3-1-default # 1 SMP PREEMPT Thu Jan 12 11:32:53 UTC 2017 (2c7dfab) x86_64 x86_64 x86_64 GNU/Linux
# dmesg | grep mmc1
[ 5.439850] mmc1: SDHCI controller on ACPI [80860F14:02] using ADMA
[ 46.398063] mmc1: card never left busy state
[ 46.398092] mmc1: error -110 whilst initialising SD card
Still the same as on yours.
If I insert an card with running
# journalctl -f
shows the following error
linux-vt4t kernel: mmc1: error -110 whilst initialising SD card
# df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
devtmpfs 950M 0 950M 0% /dev
tmpfs 958M 0 958M 0% /dev/shm
tmpfs 958M 1,7M 956M 1% /run
tmpfs 958M 0 958M 0% /sys/fs/cgroup
/dev/mapper/system-root 20G 5,4G 14G 29% /
/dev/sdb2 400M 56M 232M 20% /boot
/dev/sdb1 148M 4,6M 144M 4% /boot/efi
tmpfs 192M 12K 192M 1% /run/user/1000
The inserted SanDisk 32GB was not listed - like also at
# fdisk -l
Festplatte /dev/mmcblk0: 29,1 GiB, 31268536320 Bytes, 61071360 Sektoren
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes
E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes
Festplattenbezeichnungstyp: gpt
Festplattenbezeichner: CC66D8BE-2A4C-4B6D-833A-A3ACFA98A0FB
Gerät Anfang Ende Sektoren Größe Typ
/dev/mmcblk0p1 2048 206847 204800 100M EFI-System
/dev/mmcblk0p2 206848 468991 262144 128M Microsoft reserviert
/dev/mmcblk0p3 468992 58972159 58503168 27,9G Microsoft Basisdaten
/dev/mmcblk0p4 58972160 61069311 2097152 1G Windows-Wiederherstellungsumgebung
Festplatte /dev/mmcblk0boot1: 4 MiB, 4194304 Bytes, 8192 Sektoren
Festplatte /dev/mmcblk0boot0: 4 MiB, 4194304 Bytes, 8192 Sektoren
Festplatte /dev/sdb: 59,5 GiB, 63864569856 Bytes, 124735488 Sektoren
Festplattenbezeichner: 140E1B00-559F-465A-9E16-7D6C159CBB7A
/dev/sdb1 2048 305151 303104 148M EFI-System
/dev/sdb2 305152 1124351 819200 400M Linux-Dateisystem
/dev/sdb3 4497408 124733439 120236032 57,3G Linux LVM
/dev/sdb4 1124352 4497407 3373056 1,6G Linux LVM
Partitionstabelleneinträge sind nicht in Festplatten-Reihenfolge.
Festplatte /dev/mapper/cr_usb-Generic-_USB3.0_CRW_-SD_201006010301-0:0-part3: 57,3 GiB, 61558751232 Bytes, 120231936 Sektoren
Festplatte /dev/mapper/system-swap: 2 GiB, 2147483648 Bytes, 4194304 Sektoren
Festplatte /dev/mapper/system-root: 20 GiB, 21474836480 Bytes, 41943040 Sektoren
Festplatte /dev/mapper/cr_usb-Generic-_USB3.0_CRW_-SD_201006010301-0:0-part4: 1,6 GiB, 1724907520 Bytes, 3368960 Sektoren
and
# blkid
/dev/mmcblk0: PTUUID="cc66d8be-2a4c-4b6d-833a-a3acfa98a0fb" PTTYPE="gpt"
/dev/mmcblk0p1: LABEL="SYSTEM" UUID="66F3-AA75" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="a3f99fdc-a920-4fdc-9935-f010f462b690"
/dev/mmcblk0p2: PARTLABEL="Microsoft reserved partition" PARTUUID="670f3fc0-3f48-4705-9eb8-a4d0a5ff6f0f"
/dev/mmcblk0p3: UUID="D278F8C378F8A6FF" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="c602457f-df61-421e-b2fd-cbf7a0095eab"
/dev/mmcblk0p4: LABEL="Recovery" UUID="98C0F9B0C0F994AA" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="4de36d87-aff0-4460-87c8-fe3e57e0cbc6"
/dev/sdb1: SEC_TYPE="msdos" UUID="CF78-84F1" TYPE="vfat" PARTLABEL="primary" PARTUUID="0a14f566-4f92-4fe0-b25f-3e8e779b3770"
/dev/sdb2: UUID="de925130-3362-4b97-bf3c-1ee16aaaef68" UUID_SUB="35411fdd-3685-4602-aedd-4fd900cf430f" TYPE="btrfs" PARTLABEL="primary" PARTUUID="55c48b33-be96-4497-a5dc-9109e986a8b9"
/dev/sdb3: UUID="d6d6e9a6-9689-4775-8a92-5b0cbcfc3ef2" TYPE="crypto_LUKS" PARTLABEL="primary" PARTUUID="19d271c5-b05c-4a72-b3db-9fc3374a97b6"
/dev/sdb4: UUID="1af13b6a-31f1-4956-9029-9808b575fd83" TYPE="crypto_LUKS" PARTLABEL="primary" PARTUUID="20e21a02-b2d8-4329-b573-a953820da813"
/dev/mapper/cr_usb-Generic-_USB3.0_CRW_-SD_201006010301-0:0-part3: UUID="L4TGG9-QIvI-D5ht-tDSN-GNsi-eT67-ZK3fAQ" TYPE="LVM2_member"
/dev/mapper/system-swap: UUID="86c90162-6935-47fd-8c0d-dac493754252" TYPE="swap"
/dev/mapper/system-root: UUID="a9a05197-2006-42fe-9373-1020ba1dcfb1" TYPE="ext4"
/dev/mapper/cr_usb-Generic-_USB3.0_CRW_-SD_201006010301-0:0-part4: UUID="c3uXhl-qGzA-bHpG-xxrZ-1xCR-ulur-yvCcF9" TYPE="LVM2_member"
Ulf
