Intel® Makers
9867 Discussions
STK1AW32SC dropping wifi when USB HDD is in use
DTorr3
Compute Stick model: STK1AW32SC (Atom x5 Z8330)
BIOS: 0037
OS: Windows 10 Home 32-bit (10.0.15063)
Intel Dual Band Wireless-AC 7265 Drivers: WiFi: 19.70.0 / Bluetooth: 19.80.0
Wireless Adapter Power Saving Mode: Maximum Performance
As can be viewed, my Compute Stick is running all the latest OS update, drivers and BIOS available, but I can't plug any USB HDD without losing the internet connection. I've tested several drives, USB 2.0, USB 3.0, 2.5", 3.5", with and without external power supply, and the end result is always the same, as soon as I start accessing files on the USB HDD, the WiFi adapter starts acting crazy. There's no signal strength drop on the taskbar indicator, it simply either disconnects or continue showing as connected with full signal, but unable to open any website due to the painful slow speed.
I've tried to uninstall and reinstall all the drivers, did a factory reset on Windows 10 and even replaced the Compute Stick on warranty, but nothing changed, I still can't use an external HDD and have internet connection at the same time.
Is there any trick to solve this issue?
n_scott_pearson
Super User Retired Employee
If you are plugging these drives into the USB3 port, the issue is that USB3 utilizes a 2.4GHz signal and this can cause interference with WiFi signals. Now, this was an issue with the FC ICS, but the SC ICS is supposed to be better protected against this. Still, the external device can cause this interference. For starters, what you should try is using a USB extension cable to move the device further away from the ICS. You can also try moving to the USB2 port.
Hope this helps,
DTorr3
Thanks, Scott.
A 3 ft extension cord did the trick and now everything is working as intended.
