Community
cancel
Showing results for
Search instead for
Did you mean:
kdeho1
STK1AWSC no power button Recovery possible - is there an alternative recovery?
I'd like to chime in on my compute stick that has failed. I had a functional STK1AW32SC and was applying SCCHTAX5.86A - watching it update with no peripherals connected and during the main block flash portion the thing shut itself off - instant power down. Now it will not boot and with a keyboard connected to attempt the power button recovery I see the keyboard lights resetting every 10 seconds or so - no video and no other signs of life beyond the keyboard.
Is there a jumper or other more extreme means to recover these
Community Manager
Hello ken_nm,
Thank you for contacting the Intel community.
In this case, you can try pressing and hold the power button down for 3 seconds. Release it before the 4-second shutdown override.
The Power Button Menu displays.
Press F4 to complete a BIOS Recovery with the BIO File on a flash driver.
This is basically the option we can try to recover the system if this does not work you can try to get a warranty replacement for the unit, the unit has 1 year warranty and you can request a replacement here:
http://www.intel.com/content/www/us/en/support/contact-support.html# @4 http://www.intel.com/content/www/us/en/support/contact-support.html# @4
Ivan.
Community Manager
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
