Community
cancel
Showing results for
Search instead for
Did you mean:
AChan72
STK2M364CC bluetooth constantly dropping out
Jump to solution
Hi All
Have had this issue from day one. Running Windows 10 64 Creator version. At times bluetooth would drop out for a few seconds and then reconnect. More frustratingly is when it loses connectivity and the obly way to get it back is by turning bluetooth off and back on then reconnecting the device to the ICS. Usually a reboot would fix it as well although sometimes i need to reconnect even after a reboot.
My two devices are a Logitech keyboard and mouse. I have used them to connect to the Compute Stick Bios as well. Not sure if that matters? Was using them both perfectly on my Surface Pro 3 same version of Windows with never an issue.
These are the errors i get in Event Log after the disconnection occurs.
"Bluetooth HID device either went out of range or became unresponsive.
Source: HidBth"
Drivers are the latest versions
Wireless 19.50.1.5
Bluetooth 19.60.0.3
Bios 0051
Has anyone experienced this? Otherwise what is my next option? Can i raise a case directly with Intel?
Community Manager
Hi achandab: Thank you very much for joining the Intel® Compute Stick communities.
In order to try to fix the problem, we can try to-reinstall the chipset and management engine drivers:
https://downloadcenter.intel.com/download/26323/Intel-Chipset-Device-Software-for-Intel-Compute-Stic... https://downloadcenter.intel.com/download/26323/Intel-Chipset-Device-Software-for-Intel-Compute-Stic...
https://downloadcenter.intel.com/download/26115/Intel-Management-Engine-Consumer-Driver-for-Intel-Co... https://downloadcenter.intel.com/download/26115/Intel-Management-Engine-Consumer-Driver-for-Intel-Co...
Additionally, on the link below you will find the list of tested peripherals for your compute stick, you will be able to see a few Bluetooth devices in there:
https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017556.html https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017556.html
Sure, you can always get in contact with Intel directly in the case you are interested in replacing the stick, since we already tried all the steps recommend to fix this issue. Just to let you know, also you can get in contact with the place of purchase to verify their warranty policy and they might be able to replace it for you. On the links below you will find the information to get in contact with Intel:
Chat support: http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat
For phone support, depending on your location, you will see the contact information on the links below:
EMEA contact information: http://intel.ly/28QeAF3 http://intel.ly/28QeAF3
APAC contact information: http://intel.ly/1ITfjUF http://intel.ly/1ITfjUF
LAR contact information: http://intel.ly/29c0rW4 http://intel.ly/29c0rW4
North America: Phone Number 1-916-377-7000, Monday - Friday 7:00 AM to 5:00 PM (Pacific Time).
Any further questions, please let me know.
Alberto R
Community Manager
Alberto R
AChan72
I have reinstalled the Chipset drivers. I will monitor for the next few days and update you. Thanks
Community Manager
achandab: You are welcome. Perfect, once you get the chance please let us know the results.
Alberto R
Community Manager
achandab: I just wanted to check if you were able to test the stick and if the problem with the Bluetooth still persists?
Alberto R
AChan72
Hi Alberto
It seems reinstalling the chipset driver seems to have fixed it. It has been one week and no dropouts so far. If it happens in the future I will let you know. thanks!
Community Manager
Hi achandab: You are welcome. Perfect, it is great to hear the problem got fixed.
Any other inquiry, do not hesitate in contact us again.
Alberto R
AChan72
Hi Alberto
Seems i spoke to soon, same issue appeared again with the same error in the event logs
Community Manager
Hi achandab: We are sorry to hear the problem still persists.
In this case, besides trying to re-install the Bluetooth driver the next thing to do will be to replace the stick:
https://downloadcenter.intel.com/download/26662/Compute-Stick-Intel-Bluetooth-Technology-Based-Drive... https://downloadcenter.intel.com/download/26662/Compute-Stick-Intel-Bluetooth-Technology-Based-Drive...
Alberto R
Community Manager
achandab: Thank you very much for providing those details.
In that case to replace the stick will be the next thing to do.
Alberto R
AChan72
Hi Alberto
Is there any other solution then replacing the stick? I am worried this will occur again. Also i spent days configuring my O/S and Stick how i like. Do you have a solution to replicate the settings to another stick? I would rather avoid replacing the stick if there is a way to resolve this. It seems like its just a driver issue
Community Manager
achandab: Thank you for that information. We completely understand. The steps above are the ones that we recommend in order to try to fix this problem. We can try to re-install the chipset driver again since that fixed the issue before.
Alberto R
Community Manager
achandab: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
