Community
cancel
Showing results for
Search instead for
Did you mean:
BWill15
New Contributor II
Safe Shutdown Button/Switch Intel Galileo
Is there a way to safely shut down the Intel Galileo via hardware, i.e. a button or switch?
Now I have to connect via UART or SSH to type "halt" (I'm using eglibc).
Tags (2)
FTinetti
Honored Contributor I
I don't think so. I use to directly unplug the power... I've not had trouble so far.
I think it's rather usual in IoT/microcontrollers "world".
Fernando.
BWill15
New Contributor II
FGT I thought that unplugging a Linux system (like Linux on Raspberry Pi) without "halt" is a bad idea. I think it's better safe than sorry.
FTinetti
Ok.
I don't know about any hardware way of shutting down the Galileo card. I don't know about other cards, as the Raspberry Pi you mention.
I've never seen any suggestion/recommendation/warning made by Intel about shutting down the Galileo card. I don't know about other cards, as the Raspberry Pi you mention.
Taking into account the usage of Intel Galileo as an Arduino UNO, to execute Arduino UNO sketches, there is no specific way of shutting down beyond unplugging the power.
I was just sharing my experience, I did not suggest you do anything, neither safe nor sorry...
Fernando.
Diego_V_Intel
Hi BrechtW,
There isn't a button or switch to shut down the board. I always unplug the power supply and I've never had any issues with it.
Diego
