Hello
I want to know how I can save the sketch from arduino IDE on the board Galileo gen 2.
Happen that after I turn off the board Galileo and turn on again, the sketch is not on the board Galileo.
Is possible save the sketch on the board Galileo?
Thanks for your help.
Hello giocaba,
In order to save an Arduino sketch and make it running once the board is powered on, you have to use the SD Image. This means, you have to boot the Galileo from the SD card. I recommend you to check the following guide about how to flash the Yocto Image in the SD card: http://www.intel.com/support/galileo/sb/CS-035033.htm Intel® Galileo Boards and Kits — SD Card Setup and Sketch Persistent
Diego.
DiegoV thank you for you help. I appreciate it much.
