Intel® Makers
9873 Discussions
Send Data from Arduino (HC-05) to Intel Edison (minibreakout board)
KZama2
Hello!
I'm currently working on a project that requires me to read Temperature every 5 secs interval and sends it to the intel edison via bluetooth.
Hardware details:
1. HC-05
2. Arduino Nano
3. DHT11
4. intel edison minibreakout board
The questions are:
1. How to permanently code arduino into edison? I've tried https://software.intel.com/en-us/blogs/2015/05/19/communicate-to-arduino-code-with-your-android-phon... IoT - Communicate to Arduino code with your Android* Phone by Bluetooth Serial Port Profile (SPP) on Intel® Edison | Int… but whenever I reboot my edison, the codes that i previously compiled is gone and I need to recompile it again.
2. I've the same question as this post , but unfortunately no solution to that problem. I managed to pair HC-05 with my edison but was unable to connect with it after pairing and this Failed to connect: org.bluez.Error.NotAvailable error appeared.
My deepest gratitude to those who ever willing to help me with this.
Kharrazi
KZama2
Hi all,
Goodnews! God is gracious!
As i suspected, i need a script to call it in order for it to work. Edison seems to paired with HC-05, but it was unable to connect when you request it through bluetoothctl. It will not latch unlike android and pc once 'connect' request is prompt. It'll give Failed to connect: org.bluez.Error.NotAvailable error message if you try to connect with it. You can check whether your device is successfully paired by entering paired-devices command in bluetoothctl.
Additional info:
Here's my AT command setting on HC-05(master/slave module)
AT+UART=115200,1,0
AT+ROLE=0 //slave mode
Here's what i did, I use node.js to retrieved data from edison bluetooth serial port. I use the sample code in https://github.com/eelcocramer/node-bluetooth-serial-port eelcocramer/node-bluetooth-serial-port · GitHub . I follow the instruction in http://servicelab.org/2012/12/12/wirelessly-control-your-arduino-with-nodejs-over-bluetooth/ Wirelessly control an Arduino with NodeJS over Bluetooth | Servicelab.org , once I created the node.js script inside my root folder, I run the script on background e.g.: # node .js &
Now access bluetoothctl and follow these steps(assuming that you already rfkill unblock bluetooth at the beginning):
agent DisplayKeyboard
default-agent
scan on
//your deviceID will display here if it broadcasts
scan off
pair
//enter your pin if requested
trust
connect
// at this point your terminal will display the data fed by your bluetooth device.
exit
let me know if my explanation wasn't clear to you.
Hope this help!
Cheers!
p/s: sorry for the late update on this post. Fussy weeks lately. and i haven't tested it on HC-06 but i'm assuming it'll work the same with HC-05. the only different is that HC-05 able to switch mode between Slave or Master.
Pedro_M_Intel
Hello Kharrazi,
Which image are you using? If it is the latest image, there is a known issue with it about Arduino sketches not being persistent. Nevertheless, the user AliDouiyek found a workaround for this; take a look at it on .
Regarding your second question, can you explain to us which steps you have tried so far? On both, the Edison and the HC-05 sides.
Peter.
JCoet
I am also struggling with the same problem at the moment. I am using an Arduino micro that is connected to both a distance sensor and a HC-06 Bluetooth device. The HC-06 is basically the same as the HC-05 as they have the same firmware, but it can only be used as a slave and not as both a master and a slave like the HC-05. I can't speak for Kharrazi, but I assume that more or less the same steps were followed.
To set up the Bluetooth deviceon the Arduino, I made a software serial connection, so the code looked something like this:
# include
SoftwareSerial BT(10, 11); //Where pin 10 will now be RX and pin 11 TX
void setup()
BT.begin(9600);
void loop()
BT.println("Hello");
So the only catch to connecting the Bluetooth module to the Arduino was to make sure that RX, TX connections of the module was connected to the TX, RX connections of the Arduino respectively and since the logic level of the RX, TX pins on the module is 3.3V, a voltage divider circuit was made to bring down the TX voltage of the Arduino pin. This setup works perfectly when I connect it to my phone by using Bluetooth ssp pro as well as TerraTerm on my computer, but as soon as I want to connect it to the Edison, I get the same error as Kharrazi.
To try and connect it to the Edison, I used the following commands:
rfkill list (to check if the bluetooth is soft blocked)
bluetoothctl
agent KeyboardDisplay
default-agent
scan on (till it found my device)
scan off
pair 98:....:54
trust 98:...:54
connect 98:...:54
Then I get the error "Failed to connect: org.bluez.Error.NotAvailable". I checked with info 98:...:54 and it gave me this:
Alias: HC-06
Class: 0x001f00
Paired: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: yes
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
So the device is paired and trusted, but it does not want to connect.
Any help would be greatly appreciated.
Jacobus
KZama2
Hi Peter,
1. My edison is currently running version 159. I'll try /message/327988# 327988 Re: Run Arduino sketch on boot Workaround. thanks!
2. I set my HC-05 as Slave with 115200 baudrate. I cant get much details on the setting I made to my HC-05 at the moment, no idea why I cant access to its AT command. Will figure that one out later.
I managed to setup my sensor part (arduino nano + DHT11 + HC-05) nicely. Running smooth with my android bluetooth terminal app. and arduino serial (bluetooth) monitor. Everything works wonder.
Here is what I did to setup the connection betweeen my HC-05 with my edison:
root@edison:~# rfkill unblock bluetooth
root@edison:~# bluetoothctl
[bluetooth]# agent KeyboardDisplay
[bluetooth]# default-agent
[bluetooth]# scan on
[NEW] Device 20:15:05:22:24:02 Temp Sensor HC05
[bluetooth]# scan off
[bluetooth]# pair 20:15:05:22:24:02
Attempting to pair with 20:15:05:22:24:02
[CHG] Device 20:15:05:22:24:02 Connected: yes
Request PIN code
[agent] Enter PIN code: XXXXXXX
[CHG] Device 20:15:05:22:24:02 UUIDs:
[CHG] Device 20:15:05:22:24:02 Paired: yes
Pairing successful
[CHG] Device 20:15:05:22:24:02 Connected: no
[bluetooth]# trust 20:15:05:22:24:02
[CHG] Device 20:15:05:22:24:02 Trusted: yes
Changing 20:15:05:22:24:02 trust succeeded
[bluetooth]# connect 20:15:05:22:24:02
Attempting to connect to 20:15:05:22:24:02
Is it because my Edison is not drawing anything from my HC-05 making it to disconnect? Meaning that I need a script to call the data, no?
3. What are the differences between agent KeyboardDisplay, DisplayYesNo... etc?
sorry for the late respond.
Thanks in advance!
Pedro_M_Intel
I'm not sure why the connection is not established, I believe it may have to do with something on the HC-05 side because all you did seems fine. Can you try to create the connection from the HC-05? Is that possible? If so, is there a difference between the outcomes?
The Bluetooth agent is basically at what level you interact with the Bluetooth device to pair/connect the device. If you choose DisplayYesNo you will only have to enter yes or no, it also depends on what device you are interacting with and what it is capable of.
Peter.
KZama2
2. I'll work into that and will update here once completed.
3. thanks!
Pedro_M_Intel
Sure , let us know if you have any updates on your project.
Peter.
SAyus
Hi Kharrazi,
Have you managed to establish a connection between Intel Edison and Arduino (HC-06)? I'm having a similar problem trying to connect my Intel Edison to an Arduino Mini Pro with the module HC-06.
The only thing I've managed so far is to add to the intel edison bluetooth serial communication (SPP) following the instructions from section 6.7 (http://download.intel.com/support/edison/sb/edisonbluetooth_331704007.pdf http://download.intel.com/support/edison/sb/edisonbluetooth_331704007.pdf) . Now I'm able to connect my PC and Intel Edison and read the data sent from my PC in the Intel Edison. But I cannot connect the intel edison with HC-06. I hope that there is a solution to this problem...
KZama2
Hi all,
Additional info:
AT+UART=115200,1,0
default-agent
scan on
scan off
pair
trust
connect
exit
Hope this help!
Cheers!
SShar24
I have successfully connected my phone as BT device and did the SPP communication. But now the problem is, whenever I am trying to connect my another ECG BT sensor, I get something like this
[CHG] Device 00:0E:00:09:D8:F6 Paired: yes
Pairing successful
[CHG] Device 00:0E:00:09:D8:F6 Connected: no
[bluetooth]# connect 00:0E:00:09:D8:F6
Attempting to connect to 00:0E:00:09:D8:F6
[CHG] Device 00:0E:00:09:D8:F6 Connected: yes
How can I solve this problem? Even I downgraded my Edison and even tried with Ubilinux still get same result "Failed to connect: org.bluez.Error.NotAvailable". Pleas help me out in this critical situation
here is the full try on edison and failure status. Need your urgent positive solution to deal with my present situation as am in final semester of my masters degree.
root@edison:~# cd /home/root/bluetooth
root@edison:~/bluetooth# ls
SPP-loopback.py
root@edison:~/bluetooth# python SPP-loopback.py &
root@edison:~/bluetooth# rfkill unblock bluetooth
root@edison:~/bluetooth# hciconfig hci0
hci0: Type: BR/EDR Bus: UART
BD Address: 98:4F:EE:06:16:5E ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN
RX bytes:661 acl:0 sco:0 events:38 errors:0
TX bytes:1472 acl:0 sco:0 commands:38 errors:0
root@edison:~/bluetooth# hciconfig hci0 up
root@edison:~/bluetooth# hciconfig hci0 piscan
root@edison:~/bluetooth# bluetoothctl
[NEW] Controller 98:4F:EE:06:16:5E BlueZ 5.24 [default]
Agent registered
Default agent request successful
Discovery started
Discovery started
[CHG] Controller 98:4F:EE:06:16:5E Discovering: yes
[NEW] Device BB:A0:51:00:00:AB ZL-RC02D
[NEW] Device 00:0E:00:09:D8:F6 00-0E-00-09-D8-F6
[CHG] Device 00:0E:00:09:D8:F6 LegacyPairing: no
[CHG] Device 00:0E:00:09:D8:F6 Name: CYUT
[CHG] Device 00:0E:00:09:D8:F6 Alias: CYUT
[CHG] Device BB:A0:51:00:00:AB RSSI: -89
[CHG] Device 00:0E:00:09:D8:F6 RSSI is nil
[CHG] Device BB:A0:51:00:00:AB RSSI is nil
Discovery stopped
[CHG] Controller 98:4F:EE:06:16:5E Discovering: no
[bluetooth]# trust 00:0E:00:09:D8:F6
[CHG] Device 00:0E:00:09:D8:F6 Trusted: yes
Changing 00:0E:00:09:D8:F6 trust succeeded
[bluetooth]# pair 00:0E:00:09:D8:F6
Attempting to pair with 00:0E:00:09:D8:F6
Request PIN code
[agent] Enter PIN code: 0000
[CHG] Device 00:0E:00:09:D8:F6 UUIDs:
Pairing successful
[bluetooth]# discoverable on
Changing discoverable on succeeded
<p s...
