Intel® Makers
9881 Discussions
Send message from edison to android phone.
RJidg
Hello everyone,
I am working on an Edison module from the last few weeks. I'm trying to send a simple string from Edison module to android phone or vice versa. I worked on few
below links but could not able to get solved.
1) http://people.csail.mit.edu/albert/bluez-intro/x502.html# rfcomm-server.c RFCOMM sockets (referred other programs on the website) with https://developer.android.com/guide/topics/connectivity/bluetooth.html# SettingUp Bluetooth | Android Developers ConnectThread
2)
3)
4) https://software.intel.com/en-us/articles/connecting-the-intel-edison-board-to-your-android-phone-wi... IoT - Connecting the Intel® Edison board to your Android* Phone with Serial Port Profile (SPP) | Intel® Software in this case, android app get disconnected whenever I select "communication mode".
And I'm trying to figure it out and searching for:
1) How to verify rfcomm socket is opened and listening?
2) Is edison and android devices needed to be paired already or pairing is not needed
3) Any more specific references that can help me to understand what I'm doing wrong or any steps to get it done.
4) Any other ways to solve it.
Thanks in advance for help.
Community Manager
Hello Raul_Jidge,
If you are using the 3.0 image, you will encounter some issue when trying to use SPP as you can see in https://communities.intel.com/thread/101689 https://communities.intel.com/thread/101689. If that's the case, I'd suggest you to go back to the previous image and try again.
Let me know if you still have issues, I'll be glad to help.
Peter.
Community Manager
Hello Raul_Jidge,
Peter.
PBana3
Where can I download older version of image? I have problem with SPP in current release.
Community Manager
