Intel® Makers
9868 Discussions
Sending UART in Hex format
ARaml
Hi..Im currently using device which requires data to be send from C1000 to the device in HEX format. Some of my codes are:
uint8_t data[]={0x01, 0x04, 0x00, 0x00, 0x00, 0x02, 0x71, 0xCB};
qm_uart_write_buffer(QM_UART_0, data, sizeof(data));
However, i realized that data is sent thru UART is in ASCII instead of HEX. How I want to send it in HEX format?
Community Manager
Thank you for reaching out to /community/tech/microcontrollers Intel® Quark™ Microcontrollers forum.
We have received your request and shortly we will be contacting you with additional information.
Under contract to Intel
ARaml
Hi.. I managed to resolve the issue. The problem is actually not hex > ASCII conversion. I actually need to set the parity bit to Even (as required by the hardware), QM_UART_LC_8E1. thanks.
