Intel® Makers
9881 Discussions
Sending data from Edison to Android app through BT
MTroj
Hello I've read this toutorial: https://software.intel.com/en-us/blogs/2015/05/19/communicate-to-arduino-code-with-your-android-phon... Communicate to Arduino code with your Android* Phone by Bluetooth Serial Port Profile (SPP) on Intel® Edison | Intel® So… where is described how to send data from Android to Edison but how can I send data from Edison to Android?
Community Manager
Hi michalt38,
Thank you for contacting us. This topic has been discussed before in the community. You can find the answer to this question here: https://communities.intel.com/thread/76582 https://communities.intel.com/thread/76582 .
Additionally, there are other helpful resources I'd like to recommend. Take a look at: https://www.intel.com/content/www/us/en/support/boards-and-kits/000005743.html
https://software.intel.com/en-us/forums/internet-of-things/topic/542726
Let us know if this answers your question.
-Sergio A
Community Manager
Hi michalt38,
Do you still need assistance with this case?
-Sergio A
MTroj
I've read this document: https://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbluetooth_331704007.pdf https://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbluetooth_331704007.pdf but I did not find an answer. Is it possible to send data from and to Edison through Bluetooth using for example SPP profile? There is described only how to send data to Edison, not from Edison. I don't know how to modify SPP-loopback.py to make the script able to communicate to and from the Edison.
Community Manager
Yes, you can send data from the Edison to the Android device using RFCOMM. To test SPP using RFCOMM between an Android device and an Intel Edison device, take a look at https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-edison-boards/000008676.html https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-edison-boards/000008676.html for more information.
Let us know if this is what you were looking for.
-Sergio A
