Community
cancel
Showing results for
Search instead for
Did you mean:
rparm3
Sending photo via Bluetooth
Jump to solution
I am building a application that requires photos to be transmitted on server and on pc via ble of edison. Is it possible to use them both? and how to transmit the image using Bluetooth?
Pablo_M_Intel
Hi ravi950,
Have you checked the http://download.intel.com/support/edison/sb/edisonbluetooth_331704004.pdf Intel Edison Bluetooth Guide? There's a whole section for file transfer using FTP (File Transfer Protocol) profile. Your devices can be Window PCs, Mac and Linux systems, mobiles and your Edison board. I would suggest you to check section 6.13, which explains client and server side separately.
PabloM_Intel
Pablo_M_Intel
Hi ravi950,
PabloM_Intel
