Intel® Makers
9881 Discussions
Sensor SHT75 no funciona
AGarc20
no message
Pablo_M_Intel
Hi markiii,
Do you remember if you made any hardware changes between tests? Did you use a different image at some point? Instead of Ubilinux. It's also possible that the blocks are causing the issue, if you are sure that the sensor is working properly the blocks might be the problem. Have you tested them separately?
Also, we don't support the Ubilinux image, we only support the Yocto image. If the image is the problem you should contact the support team at http://www.emutexlabs.com/ EmutexLabs.
PabloM_Intel
AGarc20
Hi, gracias por responder
Respecto a hardware no realize ningun cambio y la imagen tambien ha sido la misma. Probe quitando el battery block y el problema no se soluciono, despues probe los pines gpio del gpio block para verificar que no esten dañados y funcionan perfectamente como entrada y salida, Otra prueba que hice fue usar alimentacion externa para el sensor, cuando conecto la tierra del gpio block con la tierra de mi fuente externa para que tengan la misma referencia sigue apareciendo el mismo error, pero si desconecto las tierras el error desaparece pero los datos leidos no son correctos
Pablo_M_Intel
Hi markiii,
In that case I would suggest you to contact the EmutexLabs support team. They support the Ubilinux image and I believe they'll be able to help you further with this. Have you tried with the Yocto image? You can try with that one and see if you get different results.
Pablo
