Community
cancel
Showing results for
Search instead for
Did you mean:
Sensor Subsystem: GPIO Not Working as expected
Hi All,
I am writing an application for reading the digital input through GPIO pins in sensor subsystem but it is not working.
I am attaching my code. Please have a look and suggest appropriately.
1. main.c: Code written in sensor subsystem. using GPIO_SS[14] for getting input.
2. quark_pin_configuration.jpg : Image to show the quark pin and function configuration.
3. schematic : Image to show the input data source. IN image on pin 4 (GPIO_PLT_LS_CLK_0) I am getting the digital input.
ERROR: IN this code I am just reading the input coming on pin4 of grove connector. It should be High low toggling but I found it always low.
Can anyone help me debug this issue?
Thanks & Regards,
Rohit
Sergio_A_Intel
Hi Rohit,
Thank you for contacting us. We'll try to help you resolve this issue. First, which board are you using?
We'll be waiting for your response.
-Sergio
Hi Sergio,
First of thanks for giving your valuable time.
I am working on board which is still under development. Its name is Mini Peak Island.
Rohit
Sergio_A_Intel
Thank you for replying back. What we meant with our previous post was what Quark microcontroller are you using? Are you using a Quark D2000 a Quark C1000 or other?
-Sergio
Hi Sergio,
It uses the Quark C1000 Micro controller. In D2000 there is nothing like Sensor Sub System.
Rohit
Michelle_C_Intel
Hi Rohit,
On the C1000 Sensor Subsystem there are 16 GPIO's. We have had some reports of issues with GPIO's 8 - 15 on the Sensor Subsystem which we are currently looking into.
You should be able to use GPIO's 0 - 7 though. Can you try one of those and let me know if you see the same problem.
-- Michelle.
Hi Michelle,
Thanks for your help.
I tested sensor subsystem GPIO's 0-7. Yes these are working properly, problem is only with GPIO's 8-15.
Rohit
Community Manager
Hi Michelle,
We are dealing with the same problems in a custom board with the SS GPIOs between the 8 and 15. Did you find the solution or workaround about this?.
We are using:
  • Curie Module (Quark SE C1000)
  • QMSI Drivers 1.3.1
  • Zephyr 1.6
Thank you in advance. Best regards,
fluiss
Michelle_C_Intel
Apologies for the delay responding on this. The issue was in the documentation - which implies all 16 SS GPIO's belong to SS block 0 - SS_GPIO_0
In fact :
SS GPIO pins 0-7 belong for SS_GPIO_0
SS GPIO pins 8-15 belong to SS_GPIO_1
Pins 8-14 become 0-6 from the point of view of GPIO block 1 so you need to take this into account when reading the pin state
e.g. qm_ss_gpio_read_pin(QM_SS_GPIO_1, PIN_OUT-8, &state)
Let me know if you have any questions. Example below for SS GPIO pin 12 ....
# include "qm_ss_gpio.h"
# include "qm_pinmux.h"
# include "qm_common.h"
# include "qm_uart.h"
# include "clk.h"
# include "ss_clk.h"
# define PIN_OUT 12
int main(void)
qm_ss_gpio_state_t state;
qm_ss_gpio_port_config_t conf;
QM_PUTS("Starting: SS GPIO\n");
/* Set GPIO mux mode. */
qm_pmux_pullup_en(QM_PIN_ID_65, true);
qm_pmux_select(QM_PIN_ID_65, QM_PMUX_FN_0);
qm_pmux_input_en(QM_PIN_ID_65, true);
/* Request IRQ and write SS GPIO port config. */
conf.direction = BIT(0);
ss_clk_gpio_enable(QM_SS_GPIO_1);
qm_ss_gpio_set_config(QM_SS_GPIO_1, &conf);
/* Clear PIN_OUT to trigger PIN_INTR interrupt. */
//qm_ss_gpio_set_pin(QM_SS_GPIO_0, PIN_OUT);
//qm_ss_gpio_clear_pin(QM_SS_GPIO_0, PIN_OUT);
while(1){
if (qm_ss_gpio_read_pin(QM_SS_GPIO_1, PIN_OUT-8, &state)) {
QM_PUTS("Error: read pin failed\n");
return -EIO;
QM_PRINTF("state is %d\n",state);
QM_PUTS("Finished: SS GPIO\n");
return 0;
