I have a Arduino Uno connected to https://www.amazon.com/Shield-Touch-Display-Module-Arduino/dp/B00Q6WN3PU this TFT display and I'm trying to send text data from Galileo's serial port to Arduino's serial port.
Pins 10 and 11 of Galileo are connected to pins RX, TX of Arduino.
This is the sketch that is running on theArduino Uno:
# include // Core graphics library
# include // Hardware-specific library
//Definicao de cores
# define BLACK 0x0000
# define BLUE 0x001F
# define RED 0xF800
# define GREEN 0x07E0
# define CYAN 0x07FF
# define MAGENTA 0xF81F
# define YELLOW 0xFFE0
# define WHITE 0xFFFF
//CS, CD, WR, RD, RESET
Adafruit_TFTLCD tft(A3, A2, A1, A0, A4);
void setup(void)
Serial.begin(9600);
tft.reset();
delay(500);
tft.begin(0x9341);
tft.fillScreen(WHITE);
tft.setTextColor(BLACK);
tft.setTextSize(3);
tft.setCursor(0, 20);
void loop()
tft.fillScreen(BLACK);
tft.setTextColor(WHITE);
tft.setTextSize(3);
tft.println(Serial.readString());
delay(1000);
If I use the Serial Monitor to send data, this works just fine, but I want it to print whatever data the Galileo is sending.
And this is the one running on the Galileo Gen2:
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
Serial.write("Testing...");
When I open the Serial Monitor it shows just fine the "Testing..." string, but Arduino never receives it.
Are you sure you have all the connections properly wired? When communicating through serial the usual connection would be the Tx pin of the Galileo to the Rx of the Arduino; and the Tx of the Arduino to the Rx of the Galileo. Make sure you're not connecting Tx with Tx and Rx with Rx. Are you using common GND on your configuration?
Can you test with an oscilloscope that the Galileo is in fact sending the proper signals?
-Sergio
Sergio, I checked and the wiring is indeed correct. Tx and Rx of Galileo and Arduino are connected and I'm using a common GND. I'll try to check with an oscilloscope if the Galileo is sending the proper signals. Thank you for your reply!
Hi JuliaFC,
Just in case you missed my previous reply:
If you connect Arduino's Rx-Tx to Galileo's Tx-Rx you will not receive anything with
run in Gaileo. Try using
Serial1.write("Testing...");
HTH,
Fernando.
Do you still need help with this thread? What were the results of connecting as we suggested?
-Sergio
Hi JuliaFC,
Intel Galileo's pins 10 and 11 are not a serial port per se..., I think you can use them as a serial port, but via some library. Furthermore
void setup() {
Serial.begin(9600);
void loop() {
The Serial library does not use pins 10 & 11 (and I think the Serial library usage does not affect any pin at all... please check, I'm not 100% sure). Maybe you can try with Serial1 instead of Serial and using Intel Galileo pins 0 and 1 connected to Arduino's pins 1 and 0 respectively. I think you will have to use a common GND, as suggested in the previous reply.
HTH,
Fernando.
