Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Serial number-Debian
Jump to solution
Hello all:
I tried to use the create_debian_image.sh in ww25.5-15 version to create debian image and build kernel.
In post-install.service(/sbin/post-install.sh), the commad
factory_partition () {
# unmount factory partition
systemctl stop factory.mount
mkdir -p /factory
mount /dev/disk/by-partlabel/factory /factory
# test can fail if done during manufacturing
if [ $? -ne 0 ];
then
mkfs.ext4 /dev/disk/by-partlabel/factory
echo "00:11:22:33:55:66" > /factory/bluetooth_address
echo "VSPPYWWDXXXXXNNN" > /factory/serial_number
fi
it seems not work in debian, every edison I always get FZEDA546D011SR501. this is not the real serial number.
Are there any way could get the rel serial number on Debian?
Community Manager
Hi xd11223,
In Yocto, the way to look at the Serial number is through cat /factory/serial_number. The output is the correct one and matches the label on the module. It's hard to say how to obtain the serial number in Debian since we don't support any image besides the Yocto image.
If you wish to download the latest Yocto image go to: https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads so we can provide better assistance.
-Sergio
Community Manager
Hi xd11223,
-Sergio
