Community
cancel
Showing results for
Search instead for
Did you mean:
ARami7
Serial to USB not working
all i get is a blank console and inputing commands does nothing
im using this kind of cable:
http://www.amazon.com/gp/product/B010KII6VG?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 http://www.amazon.com/gp/product/B010KII6VG?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
and i correctly placed each part with it's corresponding pin, for example, the tx/rx, etc. on the cable with the pins on the gen 2 board, however, when i boot and i console in my console is blank and i cant put any commands in, nor can i compile/upload
*update: i changed the COM ports to no success
under 'device manager' the COM port is named:
'USB to Serial - COM 8'
Tags (1)
Pedro_M_Intel
Hello AdanChristo,
Your description sounds good, according to it the console should work, did you make sure that the black wire on the FTDI cable is connected to the GND pin? Also, did you install the FTDI drivers?
Can you show us the configuration you used on PuTTY?
Is the board functional? I mean, can you upload Arduino sketches? Or, is there any LED activity?
Peter.
asss
Valued Contributor II
only one point is wrong in this cable: TTL level is for 5V, but need to have 3.3V.
So, need to use another cable with 3.3V TTL levels.
BR,
xbolshe
ARami7
how can i modify the cable to take in 3.3 v? buying another cable is not an option
asss
Only change 5V TTL logic chip inside the cable to another one for 3.3V.
Do not think that it is an option...
BTW, there is another model for 3.3V:
http://www.amazon.com/EZSync-connector-TTL-232R-3V3-compatible-EZsync007/dp/B010KHHD6G/ref=sr_1_1?sr... http://www.amazon.com/EZSync-connector-TTL-232R-3V3-compatible-EZsync007/dp/B010KHHD6G/ref=sr_1_1?sr...
BR,
xbolshe
asss
I guess yes. But I do not recommend it because of 5V and 3.3V mix. A reason is described there:
https://www.sparkfun.com/products/9717 https://www.sparkfun.com/products/9717
Originally, the cable was designed to have 3.3V VCC, however something was lost in translation between SparkFun and our supplier and we got stuck with a whole bunch of FTDI cables that have a slight mix up in wiring. These have 5V VCC, and 3.3V I/O. The 5V Vcc output shouldn't be a problem unless this cable is being used to power a sensitive circuit such as a sensor.
BR,
xbolshe
