Intel® Makers
9872 Discussions
Set time and date without WIFI
EBayo
I'm trying to set time and date on my intel edison arduino without wifi (i have to do that ), but the library Time.h that gets the time with time_t t = now() and setTime() doesn't work because is not for linux. i'm trying to use time.h but it doesnt have a function that update the date like now();
Can someone help me? (sorry for my English)
Community Manager
Hello Eduardo,
Thank you for contacting Intel Technical Support.
You can find the instructions for setting the time and date in the following article on page 10:
https://lasr.cs.ucla.edu/classes/edison_tutorials/timing.pdf
Hope this helps.
Octavian
EBayo
but how can i show it in the serial and set it from the ide of arduino? i dont get it
Community Manager
Hello Eduardo,
Without the use of WiFi, you can use standard linux commands to set the date and hardware clock on the Edison board. The following link provides useful linux commands to set this up: https://www.garron.me/en/linux/set-time-date-timezone-ntp-linux-shell-gnome-command-line.html https://www.garron.me/en/linux/set-time-date-timezone-ntp-linux-shell-gnome-command-line.html
In order for Edison to keep the date, you will need a RTC battery.
Octavian
EBayo
But I want to set the time from the IDE of Arduino, and refresh each second to show with Serial.print. I don't get it with the standar linux commands...
Community Manager
Hello Eduardo,
Please note that this is not included in the IDE and is not standard. Also it has not been validated on the Galileo so we haven't tested to see if it works but you can follow the example on this page that should help you out: https://github.com/PaulStoffregen/Time https://github.com/PaulStoffregen/Time
Hope this helps.
Octavian
