Intel® Makers
9872 Discussions
Silent Mode on m3 Stick?
Community Manager
Is there anyway to disable the fan of the m3 compute stick and using lower performance? The old BIOS showed an m3 mode (no fan), but I couldn't select it and since the latest version it's gone completely. I use the stick in my bedroom sometimes and the noise is really annoying and always noticeable. I would like to disable the fan, even if it would mean much less performance. Is this possible?
Torsten
Community Manager
Hello, TSGames:
Unfortunately there is no option to manage or to disable the fan in the BIOS. Did you update the BIOS version? Do you remember the old BIOS version?
Amy.
Community Manager
unfortunately, no, I don't remember the exact number, it was from somewhere the beginning of 2016 build. The mode was not selectable (the list options only showed "M1" and "M2"), but in the Description a silent mode "M3" was noted.
Is there any way to do it via software? it's really annoying when you watch videos, and to make it even worse, when I hibernate the stick, the sound driver is broken after awaking (an other bug), so the only option is to shutdown it to get it silent which is more than cumbersome.
Torsten
Community Manager
Unfortunately, there is no option to disable or set the fan to low performance in fact the fan noise is expected, the fan noise is normal and the high frequency noise happens when the CPU utilization increases is generated due to the small blade size. One of our Intel® Compute Stick engineers confirmed that this fan noise is expected, see here Intel compute Stick Stk1aw32sc weird Fan Noise post # 6.
I apologize for any inconvenience.
Amy.
